Fuel bowl????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Fuel bowl????
    Posted: 27 Mar 2020 at 8:23am
Hi everyone.
Is there a trick. Doing spring service on D17lV and changed the screen in the fuel bowl. With new gasket. Seems to leak a little. Don't remember ever haveing this issue in the past. Thought maybe even though gasket is new it still has been laying in bin for years and is dried out, needs to soften up a bit.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 8:29am
As a old mechanic I used to soak fibrous gaskets in engine oil or ATF prior to installations, for Cork nothing and limit torque, for synthetics just make certain ABSOLUTELY clean.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 8:59am
There is a 170 here that the sediment bowl base is bent from overtightening.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 9:08am
I had the same problem. It may be time to replace the entire sediment bowl assembly. It will set you back about $30. Money well spent and for me no more leaking fuel.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 9:17am
Tighten it up a little more.  I've used pliers and have never broke a glass bowl.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 9:34am
Most leaks I find are on the shut off valve.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 10:23am
With the bowl just snug, turn the bowl against the gasket a turn or so to seat it, will sometimes help and then tighten a little more,
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 11:05am
Have you checked to make sure the metal side is good and clean? If it is, put it outside and let it leak for a while. When the gasket is saturated with gas, you will be able to hand tighten it a little and it should stop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 10:26pm
Thanks guys. It stopped. Was dry today
This page was generated in 0.037 seconds.
