CA Pump and Drawbar Control Repairs |
Post Reply | Page 12> |
Dave(inMA)
Orange Level Joined: 12 Sep 2009 Location: Grafton, MA Points: 2395 |
Posted: 24 Mar 2020 at 7:21pm |
I've updated the title of this thread now that I'm into the hydraulic pump - following Hunt4Allis's footsteps there. Original post follows: The area circled in yellow shows the oil on the housing shortly after the leak appeared. The metal casing of the seal appears to have been damaged - possibly the cause of the leak? New seal is on order from Sandy Lake. Interesting that oil doesn't leak when the pump is running - finally saw it start after I shut off the tractor. More to come. Dave Edited by Dave(inMA) - 28 Mar 2020 at 5:49pm |
WC, CA, D14, WD45
Dave(inMA)
Today's project was to remove the Control unit from the tractor.
Started by removing the plug from the bottom of the control housing. Nasty glop oozed out into the pail: I hope the inside of the pump is in better shape! There are two arms attached to the control: the arm that reaches down to the Snap Coupler and the raise/lower arm. Removed the two cotter pins attaching them to the control. There are six bolts that attach the control to the hydraulic pump - 3 pairs - easy to tell each pair apart. The control is attached to the pump via the control valve lever which is secured to an arm from the pump with another cotter pin. And here's what I found inside the housing: Had to remove the lockout arm - drove the pin circled in yellow out: And then this pin in the regulating shaft: Which allowed me to drive the regulating shaft out of the housing so I could remove the oil seal. Here's a shot of the dinged seal: With the seal removed, here's the recess in the housing: Here is a picture of the arm from the pump that engages the control unit. There's no pin holding it in place. Anyone know if/how it comes off or what secures it to the shaft? Maybe a key? Now waiting for the new seal to arrive from Sandy Lake. Stay tuned! Dave |
WC, CA, D14, WD45
Dave(inMA)
New seal arrived today - thanks, Sandy Lake!
Here's the parts diagram that I'm referring to below: I gently drove the new seal (#3) into place, reinstalled the regulating shaft (#4), sliding the regulating lever (#12) on as I did so and pinned it in place. Pinned the lockout arm assembly (#18) onto the other end of the shaft. Reinserted the pivot screw (#15) and the cotter pin that secures the hand control lever (#10) onto the screw. Done....
....until I started to wonder whether I'd installed the regulating lever the right way (orientation to the regulating shaft) or the wrong way - 180 degrees around the shaft. While it's hard to know if it'd actually fit into the housing if installed wrong, this was not a good moment. While I had taken a bunch of pictures, I didn't have one that showed me enough to know that I had the lever installed right. With the excellent help of Hunt4Allis who's rehabbing his CA hydraulic pump and sent me some pictures, I found that I'd installed it correctly. Whew! Decided that I would pull the hydraulic pump and check it out to see why it is so slow to raise the arms first time around in the day. Drained the oil. Ugh. Not as bad as it could be, but I'm seeing evidence of water mixed in there. Here's a picture of a sample after sitting a few hours - you can see the liquids starting to separate at the line about 0.5" below the surface - at the red line. More fun to come! Edited by Dave(inMA) - 28 Mar 2020 at 9:58am |
WC, CA, D14, WD45
Sugarmaker
Dave,
Aren't these pumps just fun to work on? :) I would much rather tear into a engine than these pumps. I always think I am going to get them back together wrong too. But each one has worked so far. Good documentation and pictures. Regards, Chris
Dave(inMA)
Thanks, Chris. I'm going to pull the pump this afternoon. Or maybe tomorrow...not like I have places to go.
I completely get the fear of it not going back together properly - that's what's holding me back, I think. That and the thought of a spring or check ball flinging itself across the shop!
Does anyone know whether having water in the oil could cause the sluggish behavior I'm seeing after the tractor has been sitting a while? I've read that water in the oil can increase cavitation, but I'd think that the effect of that would be continuous, and in my case the sluggishness goes away after the arms have been raised once. Just wondering! |
WC, CA, D14, WD45
Hunt4Allis
Orange Level Joined: 13 Mar 2018 Location: Ohio Points: 1160 |
Pretty soon your bench will look like this🤪good luck( lots of pictures and keep everything layed out in order of how it came apart...
Dave(inMA)
Matt - that is impressive! I'll try to be as organized. I gather that you were able to drive out the cam follower pin?
Dave
WC, CA, D14, WD45
Hunt4Allis
Yes once I talk to guy at Sandy lake that works on them and he told me that they come out easily it was no big deal, thanks Bill đź‘Ť
Dave(inMA)
Removed the hydraulic pump from the CA today. It went pretty well - here 'tis sitting in an old roasting pan waiting for dissection:
Having read Hunt4Allis's posts, I removed the housing cover plate and found that the gasket between the plate and the pump has had a hard life. At least two of the pump openings were partly blocked, and parts of the gasket are gone. I've circled the blocked spots in yellow and the missing material areas in red; the larger area marked in red looks as though oil could get from one opening to another - not sure that this is a serious issue, but it's not supposed to be that way! The gasket was glued to the pump surface - came off HARD! Here's the surface cleaned up: I'm thinking that polishing it so the darker "stains" are gone would be good, but then I'll really need to take everything apart to get all the grit out. Here are the plungers before any cleanup. I don't see or feel any scratches or dings, but others may see some! Here are discharge valve plugs. Anyone know what the small allen screw plug at the left is about? It is in the parts diagram but w/o any description: Last step today was to dung out the cavity that drives the pump. Actually wasn't too gunky in there. Some carb cleaner, compressed air and a rag helped a lot. The big question of the day: is the gasket between the housing cover and pump body supposed to be glued in place? Comments and suggestions welcome!!
WC, CA, D14, WD45
Hunt4Allis
It's probably better than my gasket which was never installed which is probably why there was so much oil/ crud everywhere at the back of my tractor all the time(I thought I had found the problem when I fixed one of the hydraulic cylinder hoses a while back but now I'm questioning if it was the lack of a gasket the whole time...)
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21490 |
The allan grub plug screw 'might' be a port to install a pressure gauge ? Just a guess, been 15-20 years since I did my CA.....sigh WHERE did the time go ?
Dave(inMA)
Matt, I can see where missing that gasket would lead to a mess. After all, that pump is generating serious PSI. Were you able to order the gasket from Sandy Lake, or are you planning to make one?
Jay, your idea sounds likely to me. Thanks. Do you remember whether you glued that gasket to the pump when you rehabbed yours?
WC, CA, D14, WD45
Hunt4Allis
Yes, SL had all the parts I needed( even a used plunger that had broken!)
I should get the parts Monday so more info to come after I fix re- install pump... Big thanks to Brenda and Bill at SLđź‘Ť(they both spent time over the phone actually talking/ sending me exploded view of pump/ parts beyond what I expected. Matt |
Dave(inMA)
Great to hear. I should know by Monday what else I need. Or at least what questions I need answered. And it sounds as though Bill at Sandy Lake might know whether the answers.
BTW, there's actually a cover that was used when the hydraulic pump wasn't installed on the CA. Part # 70225195. Dave
WC, CA, D14, WD45
Gerald J.
The shop manual should have some more details of benefit.
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdfg Gerald J. |
Hunt4Allis
Man I'd love to get one of those covers!!!
Dave(inMA)
I'll ask when I call SL on Monday. Or maybe someone out there has a parts CA with the cover!
WC, CA, D14, WD45
Hunt4Allis
I can make one, not like you need it fancy or even metal for that matter ( just needs to seal off long enough to slosh some oil around in transmission to dislodge any remaining junk so hopefully once pump goes on its not getting contaminated with leftover junk...)
Gaskets went on dry as I couldn't find my bottle of 'gasket sealer' until 3-4 days later, abought same time my favorite 1/2" deep, 3/8 drive went missing....sigh. It showed up about 5 years ago for 2-3 days, then, yup, went 'walkabout' IN the garage again.... Jay
Hunt4Allis
I found what I believe to be copper never sieze between the pump and tractor rear end instead of a gasket🙄?
Dave(inMA)
Jay - what they say: "necessity is the mother of invention". Maybe that gasket is supposed to be glued on, but it sure makes disassembly a challenge!
Matt - that is weird...someone with imagination did that!!
WC, CA, D14, WD45
Hunt4Allis
Right, so all gaskets ok to be dry?( No sealer?)
My only fear is if another problem arises with pump disassembly would be easier if put in dry... |
Orange Level Access Joined: 12 Sep 2009 Points: 19551 |
No sealer on those paper gaskets will insure that you will have oil leaks. If this is OK, go right ahead.
The gasgek material I used wasn't 'paper thin', maybe 50-60 thou thick and said 'oil proof'. I can see needing glue if paper thin. I did 'polish' the surfaces real good with fine wire brush in angle grinder. if you have glue, I'd use it though...
Hunt4Allis
Dr Allis
What is recommended to use as a sealer for all 4 gaskets that are required to rebuild the pump and associated components? Is it readily available at auto parts stores or is it something special... Edited by Hunt4Allis - 29 Mar 2020 at 8:41am |
sparky
Orange Level Access Joined: 13 May 2011 Location: So. Indiana Points: 1461 |
I personally use aviation gasket sealer from Permatex. Won’t use silicone. A guy had me work on his CA pump once when he said it worked fine one day and the next day wouldn’t work. I pulled the pump and found 3 little globs of silicone in the pick up tube. I still have those globs of silicone on the bench as a reminder.
Hunt4Allis
I ended up with this |
sparky
I use the dark brown sealant in a can with a cap brush.
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8005 |
I understand all the concern about silicon but the biggest problem is everyone uses WAAAAYYY too much.
frnkeore
Silver Level Joined: 07 May 2019 Location: Southern Oregon Points: 362 |
Yes!!! Although it is hard to not use to much. As a old mechanic, I dislike "sealers" that harden. I only use wheel bearing type grease on gaskets. It seals well and will actually expand a gasket, if it embeds into it. As a machinist, I don't use gaskets to much, unless there are end play issues to be aware of. 2 machined surfaces, that are flat and have a smooth surface (a must), won't leak. They can't leak because there is no space for the fluid to migrate. If the surface has visible machine marks and is still flat, a VERY small amount of silicon will seal the machined surface. It doesn't even have to be gasket type silicon. Run a file over the surface, to make sure that there are no raised spots. Start with a amount of silicon, that you know is NOT enough and add small amounts to it. Spread it as thin as possible. Try to leave a space on the oil side of the part, for it to expand into and completely around any bolt holes. Again, a very thin coat. |
Frank
1959 D17 Series I #24001+, '59 D14 '55 & '59 Ford 850 & 861 Ferguson TO 35 Deluxe, Oliver 70 and 5 more. |
