Allis Chalmers EB Update
Valiant Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Valiant Farmer Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers EB Update
    Posted: 15 Feb 2020 at 2:51am
Hi there!
I thought I would give an update on my Allis Chalmers EB.
A few weeks ago My brother and I were towing around Allis and all of a sudden the rear wheels seized up. We pulled the cap off the right reduction unit and the bearing was rubbish, so We ended up getting a new one and installing it.
I reset the timing and it runs, I need to still do some carburettor adjustments though.
Today We Reinstalled and sealed the PTO gearbox, Final drive sump, Selector fork side plate. On Monday I hope to put the right wheel back on and give it a test run
I will try to put some new pictures up soon!
Thanks!
Samuel
Edited by Valiant Farmer - 15 Feb 2020 at 2:59am
PSALM 119:105 : Thy word is a lamp unto my feet, and a light unto my path.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2020 at 8:06am
Good to hear from you again. Good to hear you got her running. Did you source a local bearing or did you have to have one shipped in. As you know that rim looks pretty rough. One task at a time gets her done. Tough little tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Valiant Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2020 at 2:37pm
Hi there! I sourced the bearing from a local bearing shop.
Yes the rims are quite rough but thankfully the tractor came with a good set of rims to swap over!
I will try to put up some new photos today!
Thanks! Samuel
Edited by Valiant Farmer - 16 Feb 2020 at 2:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Valiant Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2020 at 3:38am
Rear view
Brake
Drawbar mounting
Old brake band
More pictures tomorrow!
Edited by Valiant Farmer - 17 Feb 2020 at 3:43am
This page was generated in 0.093 seconds.
