D17 running rough |
Post Reply | Page 12> |
Hunt4Allis
Orange Level Joined: 13 Mar 2018 Location: Ohio Points: 1160 |
Posted: 14 Feb 2020 at 12:44pm |
I bought a d17 last year and used it only to cut hay 1 time.
It ran great until the day I went to use it( when I filled tank up full) I think this washed out what I later dug out of the carb sediment bowl filter what looked like to me was a spider nest ( maybe in upper part of tank) which made it run terrible until I stopped and found it. My question is, what is the best method to clean everything out so I know the entire fuel system is good this coming year? Any tips are appreciated, thanks Matt |
TimNearFortWorth
Orange Level Joined: 12 Dec 2009 Points: 2014 |
I have had good luck by siphoning all but maybe 1-1/2 to 2 gallons out, then pull the bowl/petcock assy. completely out and let her drain.
Have found some over the years where the standpipe in the assy. was entirely gone including one found loose inside the tank and some that were corroded partially away or restricted by crud including Stabil fuel treatment. If it still has the standpipe, crud usually settles in that last inch below the top of same and gets stirred up when filled/ran as it sloshes it around. A clean bucket with a large mouth funnel and a paint filterwill show you what was in there and you may have to bung it off and repeat with a couple gallons to get more out unless you want to remove the tank entirely. Removing the tank may be needed if you have chunks of the old cork floating around that are too big to come through the bottom pipe thread port. How does the tank look inside with a flashlight? 17's use the larger bowl and NAPA has a pleated filter that fits inside the larger bowl nicely. Sounds like your carb needs to come off for cleaning/rebuild also? Rigging up a temporary tank off a lawnmower is what I use when they show up with a tank looking nasty, just to check carb status.
Brian Jasper co. Ia
I have had good results on small engine fuel tanks with filling them with pour in the tank injector cleaner and letting them sit overnight. For a tractor tank a handful of roofing nails with enough cleaner to get half an inch in the bottom and put it in the back of your truck for a few days. The sloshing around will break up bad fuel deposits so you can rinse them out.
Hunt4Allis
Well I found part of the problem today.
There were a couple spiders in the bottom of the gas tank looking in with a flashlight so I decided to pull the bowl/ assembly off after draining all the gas and I found a ladybug jamdown inside of the assembly that the glass bowl clamps onto and was clogging/ restricting gas flow. I figured that I had found the reason that it was running so rough, after putting it all back together it starts right up with the choke on but stalls within 10 seconds unless you keep pushing on the choke then it will continue to run but not the greatest... I pulled the carburetor off and plan to go through it and see if there are any obvious problems and give it a good cleaning. There's probably a good reason why when you push the choke it continues to run that I'm unaware of... Any ideas?(before I filled the entire tank up with gas when I bought this tractor it ran great, so I'm guessing when I filled it and sloshed gas around it dislodged a lot of stuff and got into the carburetor) Thanks Matt π Edited by Hunt4Allis - 21 Mar 2020 at 4:29pm |
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21451 |
hmm... PULLING the choke knob should put choke ON, PUSHING should shut it off. at least that's how all 3 of my D-14s work.... pull to start, push to run..... Jay
Hunt4Allis
It's on a spring return ( let go of knob, choke off)
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8167 |
My choke is not spring loaded. Back is to choke, forward is off choke. May want to check fuel flow again through the sediment bowl assembly. stirring up the tank may have made some other items float into the neck of the sediment bowl assembly too.
Regards, Chris
FREEDGUY
Does anyone know how the little critters get into a tank-provided the cap was always on ?? Seems like they can get anywhere :-(
Hunt4Allis
My guess is they're in the spout of the gas can when you dump gas in they get flushed in and drowned...
Hunt4Allis
I'm wondering if mine is spring loaded because of the exterior spring someone has added to it because they had problems with the choke somehow staying on? When I disassembled it there was a funky looking spring attached to the arm of the carburetor so that it has tension on it all the time...
I did check that everything was cleaned out after I found the lady bug and spiders in it and I also flush the tank out and looked in it to make sure there was nothing left... I almost have to believe that something is in one of the needle seats in the carburetor or particles have something plugged off has anyone seen because it ran fine when I bought it but only started this running rough after I filled the tank all the way full and it's sloshed around and got plugged with ladybugs and spiders... Edited by Hunt4Allis - 21 Mar 2020 at 6:21pm |
FREEDGUY
Our choke cables were/are a "friction" type deal, in fact, the 180 is somewhat a "tug" to pull out. Seems like the WD was spring loaded though ??
Sugarmaker
My uneducated no data behind it guess, is that most were not spring loaded from the factory but someone may have added the spring to avoid the choke being left on? That being said. The choke on my Ford Jubilee is spring loaded and if cold I have to put a clip on it to keep it running for a while till it warms up. Most of the Allis tractors I have played with WD series mostly did not have a spring on the choke.
Regards, Chris
Hunt4Allis
here's my ladybug where I found it( it's yellow) d**!? I thought for sure once I find it along with 2 spiders that I'd reassemble and be running great again but now I'll dig into the carb.
I'm wondering if I'll need a carb kit( not sure what make/ model of carb it is yet) I know my "b" is a marvel s.) Any info is appreciated π |
FREEDGUY
Parts Book lists #70210742 as the choke return spring. We had a clip to hold the choke rod 1/2 out during warm-up as the spring would pull the rod back :-) |
Hunt4Allis
I'll take some pictures and post them of carb tomorrow maybe...
Keith M
Silver Level Joined: 17 Mar 2020 Location: Kentucky Points: 50 |
My WD-45 does Not have a spring on the choke and never did. Mine got to where I had to pull choke out to keep it running while raking hay last fall. Rebuilt the carburetor and she ran fine pulling the grain elevator. So in guessing you need carburetor kit put in. Just guessing mind you. Duh I just realized this was D-17 post. My D-17 is a diesel so idk about cable π
Edited by Keith M - 21 Mar 2020 at 9:50pm |
Hunt4Allis
No cable on mine it's a rod(1959)ok thanks
Anyone know what carb kit I'll need? And yup, have no idea why this changed to a wd45 talk( header says d17)π€ͺ Edited by Hunt4Allis - 22 Mar 2020 at 6:04am |
Dave(inMA)
Orange Level Joined: 12 Sep 2009 Location: Grafton, MA Points: 2395 |
Your carb could have jets partially blocked from particles that came along with the ladybug! Take it apart, remove all the jets and clean with carb cleaner and compressed air - maybe a couple of times. Same thing with all the passageways in the carb body. And the fuel line and float valve in the carb. All it takes is a tiny bit of crud in the carb to really mess with how it performs. If necessary, rinse and repeat.
WC, CA, D14, WD45
Hunt4Allis
Yep, probably doing starting in a bit so I'll see what I find.
I need to clean about a quarter inch of crud off the outside just to hopefully be able to see what brand it is then I can maybe get a model number from it also... |
Sugarmaker
My D17 has a zienith carb, and seems to run fine with it. I like the Marvel carbs better for some reason. Just used to them I guess. Your tractor may have a Marverl TSX464. Look for the small brass plate riveted on under the flange area. I liked the kit I got from Sandy Lake when i did a 464 carb refurb this winter.
Regards, Chris
Hunt4Allis
Ok thanks, I'll look for it.
Hunt4Allis
It looks to be a TSX 773 with a number 59 under the TSX part and number three under the seven seven three part here's 2 pictures of my carb off d17.
Edited by Hunt4Allis - 22 Mar 2020 at 9:03am |
Hunt4Allis
I bought a carb rebuild kit just incase after I open it up I think I need new parts, on my time off work...
More to come. Thanks Matt |
Sugarmaker
Matt,
You will need some of those parts in the kit. I used all the new parts and put the old ones away for spares. Regards, Chris
Hunt4Allis
Right, gaskets and other stuff I'm sure.
I'm cleaning up the outside in a parts cleaner now... Thanks Matt π |
Hunt4Allis
I'm really hoping it's a issue with carb and not the gov or something else, but it seams like it should be b/c all this issue started after I filled tank completely and drove 200 yrds.before that tractor had no issue with running although now that I'm thinking back when I initially test drove it it was sputtering under load of a hill at owners place where I bought itπ.but this is completely different in the fact that now I found the orifices blocked completely by a ladybug and spiders( got that taken care of last weekend) and even after all that cleaned out including the tank itself it would only stay idling when I pushed the choke lever every 10 seconds or so and if I let it go more than that it stalled...
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22807 |
If you are using a rubber gas line between the sediment bowl and the carb, that may be adding to your problems. They can look fine on the outside, but start breaking down internally and fill little holes in the jets with pieces of rotted rubber. I know it's the easy way, with rubber hose, but the original steel lines worked fine for decades and are still the best way to go IMO. I had the neighbors 770 Oliver here some years ago and it would run fine for maybe a couple minutes, maybe 5 or more, then die like you shut the key off. I kept thinking the coil or condenser was bad. Come to find out, there were about a dozen of those stinking 'Asian' lady bugs in the tank. They must be able to skinny in thru the gas cap somehow,, when looking for a winter home. Edited by CTuckerNWIL - 25 Mar 2020 at 8:44am |
Hunt4Allis
I know, it's on my list to do( came this way last year when I bought it)
I'm not sure if there's a premade one I can buy or not? Either through the crevices on cap or follow my thought here... Spiders catch them and retreat into the neck of you gas cans which in my case would explain why I found 2 spiders and Asian lady bugs in tank.you are putting all of it into your tanks inadvertently. It has made me check all my gas/ fuel necks before I use them( which I never thought of this before my findings in my d17 tank/bowl assembly and possibly the carberator ( I'll update this post after I clean carb out) Thanks Matt Edited by Hunt4Allis - 25 Mar 2020 at 11:12am |
Hunt4Allis
Just cleaning the years of gunk off the outside, inside and rebuild to come. |
FREEDGUY
Just out of curiosity, if the exterior of your 'carb looks like that, what does the rest of the block look like ? That thing is a disaster externally IMO.
