I've been talking with Nelson Muffler Co....
 Post Reply Post Reply Page  123 4>
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Topic: I've been talking with Nelson Muffler Co....
    Posted: 03 Dec 2019 at 1:51pm
I have been talking with the Nelson Muffler Co. (Nelson Global Products) for the past couple weeks about producing a run of obsolete mufflers. I chose the oval muffler for a 170 Gas tractor to try to get produced. The reason I chose the 170 gas muffler (A-C #249324) is because it is extremely close, in dimensions, to the late D17 oval muffler (246129), the 170/175 diesel muffler (250049), D19 gas muffler (246130), and 180/185 muffler (248883). And therefore would require very little modification to fit one of the above tractors. Granted, i'm sure the differences are supported by reason, but this solution is a compromise because ordering a production run for each of the 5 different mufflers wouldn't be feasible. I have drawn schematics for the mufflers so you can see how close they are. I will be working with a local shop to get the mufflers modified with a different input pipe diameter and output pipe diameter if necessary for the different applications.
Nelson ultimately said they would be willing to make a production run of 100 mufflers of the A-C #249324. I spoke to them this morning and they are going to get back to me with a cost per muffler and a confirmation that they still have the tooling to make them.
The Nelson for WD45/D17 I can get for $125, so I estimate the cost for this newer oval one at around $200 per muffler. A run of 100 mufflers at $200 per muffler is more than most can afford, so it boils down to this: I need to get orders for 70-75 mufflers to go through with this order.
This post is just to get the word out that there might be light at the end of the tunnel for these mufflers. Do you think that I can get the 70-75 orders necessary? Would you be okay with putting this muffler on a D19 or 175 diesel if it was modified to have the proper inlet and outlet pipes? Keep in mind the oval body size and baffles will be of the specs of the muffler that I will have produced. Any comments, suggestions, ideas, etc.  are valued from members with more experience and wisdom than me
www.awtractor.com
A&W TRACTOR 920-598-1287
Dave Wisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 2:54pm
Ok if that 200 price will include the right pipe for the D17 series 3 and the sound is correct I would buy one.
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 3:09pm
If you can get an original style Nelson muffler for the late D17s for $200 you will sell your first 100 very fast.
Just had a customer ask if there were any available the other day.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 4:58pm
Have you mentioned the CA muffler? The same CA muffler would fit the late B tractors, early D10/12 tractors, D14 and early D15 tractors without any modification on the entire group.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 5:52pm
Would it fit a series 4 diesel?
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 5:54pm
Will the outlet be in the center or offset. I think the original ones were offset, no?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 6:02pm
I know the D15 oval was offset and I think the 170 was too. Tracy
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 7:03pm
I am following this post because I will need a muffler for my D17 IV gas. I thought a post was here about a week or two ago that had a link to were Nelson Global still had these mufflers? Maybe they could be sold out? Anyway, I would definitely buy one. Ryan
MDWilliams338 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MDWilliams338 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 7:09pm
I too am actually in the market, for a newly acquired D19 that most definitely is in need of a correct muffler....in short,Iโ€™m in๐Ÿ‘
โ€˜42B,โ€™45B,โ€™48C,โ€™51CA,โ€™52CA,โ€™69170,1935WC,1936WC,WD,WD Highcrop,WD45,WF,D10/14/15/17/19
It isnโ€™t how you die.Itโ€™s what you live for.-Daniel Boone
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 7:11pm
If it's the original style with the offset outlet I would buy one.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 7:59pm
Alex, my suggestion is make all the bases 2 3/8" and then supply a bushing to slip over the pipe on the manifold.
  I bought a cheap stanely muffler off Ebay one time and it was for a 170/175 diesel muff...  I made a bushing for it and slipped over manifold pipe and then slipped the muffler over that and been on for many years... and the 2.25 od top side didn't really change the sound that much...Figured the engine breathed easier.   Suppose Nelson would make them out of Stainless steel? might sound tinnier and turn blue but... might not rust out ever again.
 Tracey, some were... some were put on to the front and some were put on towards the back and then they had the center ones too...  Our 170 was to the back... my uncles was to the front... and the neighbors IV was to the front...
And the series IV...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 8:12pm
Count me in Alex , I would take a chance at a correct Nelson muffler . If they look , sound good I know they would sell fast . I would think some vendors on here would be interested .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 8:15pm
I am talking about the inlet, on the bottom. I know the tops were offset. I have and old one at the farm. I remember Skyhighballon and myself measured it. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 8:38pm
The 180/185 mufflers and D15/D17 diesel mufflers are also close in dimensions and I might be able to offer them also.
I know that some mufflers originally had the offset such as D17 gas, 170 gas, 180/185 tractors.  I am NOT 100% sure that any of the oval mufflers originally had centered outlets, D17/D15 diesel maybe, 170/175 diesel maybe.
I do know it boils down to which tooling and dies Nelson still has on hand. If they have the offset dies, thats what they will make. If they have the tooling for the centered outlets, it is what it is.
While I will be modifying the diameter of the inlet and outlet, I do not think I will be modifying the LOCATION of the oulets. I also do not think I will be changing the length/height of the oval body, which means that if your tractor had the oval body that is a different height than 16", it MIGHT NOT sound exactly like one from the 60's even though the inlet and outlet diameters will be modified for the application. I want to be up front with everyone, so no one is expecting something different.
For example: the D15 series II muffler has a body length of 12.5" and inlet/outlet dia. of 1.75". I can change the inlet and outlet pipes to 1.75" but since the body is 16" long on the mufflers that are getting ordered, it won't get changed to the 12.5" that it is supposed to be. Since that is so far off (3.5") I won't be offering a D15 muffler since it would obviously be noticably different.
The 170/175 diesel muffler body is 18" long, which is only 2" longer than the body of the  170/175 gas muffler i hope to order. That would be an okay compromise for most folks I hope because, like I said before, it is not feasable order 100 each of 5 different mufflers to offer perfectly original ones for each tractor.
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2019 at 7:29pm
Alex, "I am NOT 100% sure that any of the oval mufflers originally had centered outlet"
 From looking at pictures in old allis lit.,  they had outlets in the center too for many of the tractors... Have a few pics with the outlet almost on the edge and ran across one picture where the outlet is just a bit offset just enough to miss the center pipe. Almost like some of these muffs were in the experimental stages.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2019 at 8:29pm
I priced a Nelson for my D 15 in August . It was $560 . Sounds like a very good deal .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 7:07am
One-Seventy/175 gas mufflers were identical to D-17 S3/S4 except for the length AND diameter of the offset outlet pipe, which is a little larger diameter.  I'd have no issue with buying a One-Seventy/175 gas muffler for the D-17's and just whack off the extra tail pipe length and the slightly larger diameter would never be noticed by 90% of on-lookers. Engine would breather easier anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 9:41am
For example: the D15 series II muffler has a body length of 12.5" and inlet/outlet dia. of 1.75". I can change the inlet and outlet pipes to 1.75" but since the body is 16" long on the mufflers that are getting ordered, it won't get changed to the 12.5" that it is supposed to be. Since that is so far off (3.5") I won't be offering a D15 muffler since it would obviously be noticeably different.
Alex, if you are going to the trouble of having them made, I would get correct ones done. Might team up with several suppliers to get the quantity up to feasible numbers. Dies are not normally easily changed in those increments. If Nelson has the dies, get the correct ones.It will pay out in the long run.  JMHO Tracy
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 12:47pm
I'd be interested in one for a series 4 diesel and perhaps for a series 4 gas too.
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 7:04pm
This is awesome. I sprung for a true Nelson for the WD and the build quality is fantastic. Best of luck getting this run made!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 8:05pm
[/QUOTE]
Thanks Tracy- So you are saying I should consider getting a run of 100 mufflers for every different application? like 100 of late D17/170/175 gas, 100 of D15 series II gas, 100 of D15/D17 Diesel, 100 of 180/185, 100 of D19, and 100 of 170/175 diesel.
In a perfect world that would work. Of course the Nelson Muffler Co. would have to have the tooling/dies for these also. But if they did have the tooling, I can see this happening one of 3 ways:
a)   I get enough preorders, like 70-75 of each style muffler, and then have Nelson make a run of 100 in each design. And if I can't get the 70-75 orders, then contact some parts suppliers if they would buy some?
b)   I take each style muffler one at a time. First do the late D17/170/175 gas style (seems to be the most popular), get the orders, pay for the 100 mufflers, and deliver the orders. Then do the next style D15/D17 diesel for example. And don't do my current "modify the inlet/outlet to application" style of current thinking
But to think I can sell 70-75 of each style muffler might be pushing it. That would be 600 mufflers at once, unless I did one style at a time. And even then, the odd ones like D15 series 2 gas, and D19- My personal opinion is I don't think I could get 75 orders for those specific mufflers, which means only the more popular mufflers would go through I would kind of like to give choice "b" a try though. That would save the extra dicking around cost of modifing the inlet/outlet pipes.
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 8:09pm
I am sure on the 175 diesel now, my original operator's manual has a pic with the centered outlet. I also remember seeing a d17 diesel muffler at Alex (wi)'s stand at the Union Grove GOTO this past september- I believe that muffler had a centered outlet.
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 8:18pm
So to summarize what I have observed as the consensus here:
1)  If the original muffler had an offset, only new mufflers with the offset would be worth getting made.
2)  If the original muffler did not have an offset, it would still be worth getting made because it outlasts the Stanley and has the "Nelson- Music to the ear" sound
 example: Nobody would buy a new Nelson for there D17 series IV gas if it has a centered exhaust outlet, even if it sounded like a Nelson
Edited by Alex09(WI) - 05 Dec 2019 at 8:22pm
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 9:17pm
Alex I would try and talk with a few vendors on here and try and get some input on demand . I would think if they were correct , high quality , and sounded good they would sell like hot cakes .Oval NOS Nelson mufflers at the Missouri Swap Meets do not last long , any make or model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 9:48pm
Alex, From various pieces of literature, I see BOTH the offset and center mufflers used on the D17 IV, 170 and the 175, both gas and diesel... and most of them had center pipes in the pics...
 So... center pipes would be just as correct as the offset pipes... just the fact I know our 170 gas came with offset to the rear
  Guess I would find out what dies/tooling Nelson has left and figure it from there.
 As for the 180/185, All pictures in literatures I seen were offset, gas and diesel..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 8:00am
I've never seen any series 3 or 4 D-17 gas with a Nelson centered outlet muffler in real life. There may have been some pictures with them, but remember prototype pics don't  always mean that is what production was. Some Nebraska Test pics could be used to verify. I looked at an S-3 last spring that only had 5,000 hrs on it with an original Nelson muffler and it was offset. Also, if there was an early run of S-3 D-17 gassers with a center outlet, they were soon superceded by a replacement muffler that was offset. There was never a One-Seventy or 175 gasser with a centered outlet.
Edited by DrAllis - 06 Dec 2019 at 8:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 8:17am
[/QUOTE] Alex, what I meant was call around to others that sell them and pool your resources. I understand you can't sell that many by yourself. But if you, Steiner , DJ'S and others could easily. Purest won't buy it if it is not pure, others won't buy it if it cost as much as pure! HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 2:17pm
As far as D17 gassers go, i distinctly remember the sound of the original factory Nelson oval with the offset outlet. The sound of the Stanley's with center outlet is nothing special and one can be picked up at most fleet supply stores for 60 bucks. I think the offset had something to do with the Nelson sound, maybe because the exhaust couldn't just flow straight up and out. Maybe I'm crazy but I'm sticking to this theory.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 7:21pm
I would be very interested in a Nelson muffler for my gas D-17 IV.
Edited by WF owner - 06 Dec 2019 at 7:21pm
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2019 at 8:58am
I have a long way to go but that would help in this restoration project.
I am interested. Don't know where dad got this muffler. Too young to remember the details.
