Hd11 outer bearings |
7060
Orange Level Joined: 16 Sep 2009 Location: Missouri Points: 1142 |
Posted: 23 Nov 2019 at 12:19pm |
I am doing some maintenance on my hd11E and decided to change the final drive oil. I wanted to pull the caps off the outer bearings and wondered how to check the preload?
Lazyts
Orange Level Joined: 05 Feb 2012 Location: Manitoba Points: 627 |
The preload is measured by rolling torque with the truck frames and seals removed. The best you could do short of that would be to pull a couple of shims.
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29459 |
THIN Shims as you do not want to cook those.
Tad Wicks
Orange Level Joined: 27 Mar 2011 Location: Shandon, CA Points: 2160 |
What you might do, is remove all the shims and then put the cap back on, torque to 15-20 inch pounds, use a feeler gauge around the shim area and average the gap then match that gap with the shims and add about .015 inch then torque to 35-40 foot pounds. Remember to tight is worse than to loose. Just my thoughts.
LeonR2013
Orange Level Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
After you set the preload see if you can shake them at all. If a little loose, tighten them a tad and check again. If no shake and turns free, buckle her up. Run it a while then get your lazy butt off the machine and see if they're getting warm or hot. Recheck. (Requires getting off again. You get the procedure.) Leon
