Buying a Tractor- Opinions on this Allis 7040? |
Post Reply | Page 12> |
Author | |||
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4786 |
Posted: 06 Dec 2019 at 8:33am |
When stopping, push clutch pedal down to just about the bottom of travel. The last inch or so of travel is for the transmission brake, so you don't want to be applying that when tractor is moving. It is only meant to stop the gears from free wheeling, to allow you to shift without grinding. You'll get used to it really quick, that if when wanting to shift the 5 speed, and it doesn't quite want to drop into gear, just release the clutch pedal an inch or so, to allow the shafts to slightly rotate. It will drop right into gear once you get the hang of using the inching(clutch) pedal.
Sponsored Links | |||
matador
Orange Level Joined: 10 Nov 2014 Location: Wyoming Points: 1727 |
That makes sense- just like how our White was- They're unsynchronized gears. You never change anything other than the foot buttons while moving
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11422 |
Just to add/ clarify a bit what the guys are saying, yes you shift the buttons on the floor on the fly. What I think is lacking in this statement, is you shift the range and gears at a COMPLETE stop, not just "clutched", unless you're very experienced and a bit lucky. Guys say they do it, I don't, you're supposed to be stopped to shift those.
farmboy520
Orange Level Access Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |
To answer your question on how to shift the 7040 power director tractor with it running: 1st push the clutch in, 2nd you take the range lever out of park and select either high or low with the lever that is towards the front of the side console, 3rd select which gear of the transmission you want with the lever between your legs, 4th let out the clutch slowly, 5th you can then use the button on the floor to shift from low to high for the power director. When you press in the clutch, the power director should return to the low side. I hope this helps
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
AllisFreak MN
Orange Level Access Joined: 07 Dec 2009 Location: Minnesota Points: 1505 |
I bought a 1975 model 7040 PD a couple years ago and really like it. It needed some lovin' but I got it reasonable, not quite as cheap as you did. The main issues I had with it were leaks. 2 of the four long hydraulic hoses running from the steering cylinder up to the steering wheel were leaking bad, wore through from tilting the steering wheel for 40 years I guess. Right where they enter the cowling under the hood going into the cab. Not a real fun job but got 'er done, did all 4 hoses since I was in there. The exhaust manifold was cracked/leaking so bought a used center section and fixed that (3 piece manifold). The power steering cylinder seal was leaking so that was another thing I fixed. Return?? line from injector pump was cracked and dripping fuel so fixed that. Drain plug in side of engine block was drooling anti freeze, of course when I went to tighten it she broke off so had to drill that out and clean up threads - fixed that. It seemed like it was leaking from every orifice at first but now they are all fixed and she stays pretty dry. Put 4 new Firestones on it last spring so I assume they will outlast me. Also replaced the non working Niehoff alternator with a new Shoup Delco. It is also way overkill for my little farm but you can get them so darn cheap it's kind of a no brainer. The 20 speed is easy to drive, just a Hi Lo range lever to the right and a 5 speed stick between the knees, then you can shift the hi lo power director buttons on the floor on the go. Every time you clutch the power director automatically goes back to the lo side. The 426 is a nice sounding, strong engine for that hp range. A little thirsty compared to the 301 but not too bad if you're not working the snot out of it. Good luck with your new toy.
matador
I'm not a fan of them either- the duals are pretty worn out too. Our old 4520 Deere had an Armstrong on it and it wasn't anything great either. When it comes time for tires, I'm going for the Firestone style- they just seem to pull a LOT better. Then again, when you're baling straw, you really don't need much in the way of pulling power
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7950 |
Good buy and nice tractor ! My personal opinion I hate those long bar short bar tires, got them on a 6080 and always spinning on green grass,
matador
Pictures will come as soon as we can get it. Tomorrow, I'll spend probably half the day getting the neighbor's Kenworth and Lowboy out of the snowbank it's parked in. No clue when I can pick it up, but I like to pick up auction winnings as quickly as I can. I'd rather have something sitting in my yard than someone else's.
For the straw operation, it's total overkill. But, I won't complain- getting working A/C is going to be nice. As for your modern tractor question, it's hard to tell since HP ratings have changed some. But, sticking with AGCO, it looks like a Massey 7718 is pretty close to the size. The only new one I could find on TractorHouse is a 2017 model with 15 hours on it. The asking price is $115,085. You could have that, or just over 27 of this Allis 7040 for that price. Seems like a no-brainer to me. Anybody have any ideas on the stuff to look over this winter with a fine tooth comb, and also, this will sound like a stupid question, but how the heck do you drive the 20 speed on that thing?
Sugarmaker
matador,
Congratulations on the 7040! Now we need pictures please! Sounds like a lot of tractor for the money too! Should make a nice addition to the farm operation. What would an new tractor of similar size and Hp cost today?? Regards, Chris |
Lonn
Wink I am a Russian Bot |
matador
Alright- the auction ended today, and for the price of $4200, we now own that 7040. Is that a good price- it seems insanely cheap to me, but it's hard to tell out here where tractors are harder to find
So, before spring, what are the common things on these tractors to need working on? From what I've read they seem pretty bulletproof, but any machine has it's points that need a little extra care
darrel in ND
Orange Level Joined: 22 Nov 2009 Location: Hebron, ND Points: 8588 |
Yes, I am sure that you are correct. Darrel |
matador
@GM
Thank you so much for the advice! That's the type of stuff I needed- the good, bad, and ugly on these things. I now know what to look for when we check it out. We don't plan on driving it 130 miles, though you could. Wyoming has a CDL exemption for ag stuff, so we could use one of the neighbor's Kenworths to haul it back. I need to just get my CDL one of these years, but that's low on my list of worries. Hopefully our White isn't in a real bad way, but turning two into one may be a better idea anyways. Ehhh, who am I kidding? I'd probably just end up with two Whites and an Allis. I see what you mean about that whole "black hole" thing you mentioned Seriously, it's nice to know that it's out there. Terry is pretty busy this year since the beet farmers lost a lot of money this year (Neighbor only got 300 out of 975 acres dug- rest are a total loss), so a lot of people are forced to use the "Can I get just one more year out of her?" approach. I doubt a White with a failed transmission is your top priority now anyways Out of curiosity, how bad is it to replace the transmission on a White? It sounds like the engine and clutch are pretty easy for a mechanic to do
Michael V (NM)
Orange Level Access Joined: 12 Sep 2009 Location: NM Points: 2345 |
GM guy covered a lot of things to look at, even a lot I haven't thought of,,
I prolly went too much on the 7060 I bought on an online auction,but it has turned out to be a decent tractor,I had to some work on it,but that's prolly the way with anything bought at an auction.. Another thing you might do,is, search past auctions for 7040's, this will give you an idea of how much they have been selling for, don't limit search to Big Iron only, do auctiontime and purple wave also.... |
GM Guy
Orange Level Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1973 |
Thanks(1)
7040 maroon belly gear drive (power director) is probably what will come up in the dictionary for "low operating cost" Everything is rather rugged, and affordable.
We have a 2-105 in Idaho with a munched transmission (previous owner didnt know about the 6 spd and rear end having their own separate oil) if you want to make 1 out of 2. but like said above, oil in water is hopefully oil cooler, and Whites are the most "farm friendly" tractor to work on the clutch, since no splitting stands are needed. Though I would highly suggest having 2 tractors. within reason, its never a bad idea to have extras. I say within reason, because after too many it gets to be a black hole for $. Usually that issue only arises at double digit quantity though. :) Definitely go inspect that 7040, without an inspection stop bidding at 1500. make sure and drive it and make some sharp turns and listen for noise, quite a few threads on this very forum of guys repairing differential carnage on 7040/8030 tractors with the big engine and 2 pinion differential. The rest of the inboard planetary rear is basically bulletproof. Allis approved full 3pt loads on 120 centers on single tires, no one else would. make sure both brakes work, we have a 7040 with one dead brake, I am going to leave that Pandoras box alone... lol Cab is cozy, make sure door is not broken. if it is, find someone good at welding thin metal (not me. :) ) and get it straight and weld it back together. lube the catch ball, or get the door shock kit. rusty catch ball is why the doors get broke up in the first place. the joy of a a 7040 is that version of the 426 will out start basically all other 7000 series tractors, and the small cab warms up quick. we have a 3pt forklift on our 7040, and plugged in it will go at any reasonable temperature to unload trucks. Both assets in Wyoming. :) I am sure you know already, but make sure and run thinner engine oil or a oil pan heater. neighbor bought a 7080 that came from WY (we sold it to a guy in CO years ago, his estate sold on Big Iron, it went to WY, guy ruined engine and dumped it back on big iron, where our neighbor bought it) near as we could tell, cold thick oil didnt flow and starved it of oil and piled up the bearings. For baler use, IMO I would leave the 540/1000 PTO in the 1000 position, use a hand tach to figure out what engine RPM gives you 540 RPM, and use an adapter. That might result in too much torque and inconsistent RPMs, so you might end up running it on true 540, but the engine will be revved up and fuel consumption will increase. I do the adapter on 1000 RPM setting on our 7040 when I pull the 5 ton dry spreader with 540 PTO. One thing to check when you inspect it, remove the PTO stub and look for sheared off bolts. (take a 5/8 socket and a long extension, Caterpillar 7/16 bolts will have an 11/16 head, but those only work on one side of the PTO, so doubt it will have those, but take an 11/16 just in case) The concept is relatively foolproof, but some folks either let it run with loose bolts, or tried ramming bolts in where they are not supposed to go. I have a 7030 that one side of the PTO is un-usable due to this. When you do use it, make sure and torque bolts with engine idling, PTO will freewheel with engine off and you cant get good torque. Otherwise, take a wrench to crack drain plugs, look for antifreeze in oil on engine, and gunk and water in the transmission and rear end. trans and rear are seperate, rear end oil level is via two sight glasses on LH side, fill by 3pt, and trans is dipstick under seat. 3 drain plugs on rear end, 2 on transmission. plastic sealing washers love to split, so be careful, and if you buy it, get new sealing washers for when you go to change oil. So overall I think it would be a good addition to the fleet if it goes for a decent price. Like you said, the $ saved on trucking would add to the value. 130 miles is a little ways to drive it, but if she checks out, should be able to make it fine. Good luck! |
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
injpumpEd
after looking at the pics on the provided link above, I see it does indeed have 2 speed pto, with the 540 set up currently. It does almost look like the wedges for the innder right rear are loose, wish could zoom the one pic of the back that shows the right axle inside.
Michael V (NM)
The wedges are similar,I think you can look on the inside of the wheel,maybe you can see from there, I just thought it was strange to have the rear wheels at different spacing
matador
Our crops did alright. Beets and beans out here had a terrible year, but we only grow grains, so we lucked out this year. Everybody else out here is having the worst year I can remember though. Hopefully that’ll mean nobody has money to buy a tractor so it’ll go cheaper
As for the tire spacing, I couldn’t see into the rim well enough to see how they work. Our neighbor had a run on a Deere 4320 loosen up where it came off the wedges and needs to be welded. Do these tractors use the same type of setup, or are the axle wedges you mention something different? |
injpumpEd
I'm not positive, but pretty sure all 7040's would have dual speed pto. Seems the only one that is not is a 7080 and 8070. At 135hp, the 7040 has to be one of the most reliable tractors of the era.
Michael V (NM)
I looked at the pictures, when ya go look at it, check and see why the RH inside rear tire is set at a different width, they might have had a reason,, or could be loose wedges on the axle...
After you go look, decide on your bid, and stick to it, don't let their "outbid" emails change your mind... |
JohnCO
You know there are thousands of older MF combines out there not being used as something other then the engine wore out. Lots of them have the 6-354. Sounds like you need to talk to the great mechinic you have nearby to see if he has worked on Perkins engines. Pretty likely he has. If it' s just the oil cooler you might get lucky, BUT, having antifreeze in the oil is not good for bearings, etc. How did your crops do this year?
Allis Express participant |
matador
I plan to look at it- we've toyed with the idea of two tractors for years if nothing else. Sounds like these are pretty solid, reliable machines at least
darrel in ND
One thing that the ad doesn't mention is that the 7040 does have the inter-changeable PTO, so you would have both 540 and 1000 PTO. As far as the tractor being too big, that shouldn't be a problem because the baler should have shear bolt protection. And the size will keep the back and forth motion in check. I guess, all things considered, I think it would work for you. If I were you, I definitely would go look at it and test drive it before you bid on it. Darrel
matador
Cab amenities have never bothered me- when the snow is flying, I remember the days in our Deere 4520 with no doors or back window. I'll be more than happy with any company-made cab I worry about reliability and weak points, not creature comforts
GregStremel
Bronze Level Joined: 06 Aug 2013 Points: 81 |
I have and use a 7040. We rebuilt the engine soon after we bought it about 25 years ago.
At first it was our main tillage tractor. It has been replaced by a couple of 7060s and an 8070. I now use it to pull fertilizer buggies, cut hay, Ted hay, rake hay, run the round baler, and a 20 brush hog. In short, it is a versatile tractor. I felt it was ridiculous to use a 135 hp tractor to Ted hay, so I used our D19. Until, it was100+ degrees. Then it was silly to use an open station tractor when a tractor with a/c was right there. I am 6’2” 230 lbs. the cab is smaller than the 8000 series cabs. But I have enough room. I have been known to work with a German Shepherd and a fat Black Lab in the cab all day. Crowded but doable. |
exSW
Orange Level Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
6-354 Perkins is a world wide engine. Parts should be out there.Also Ed mentioned it but I will again. PULL PTO FIRST !
injpumpEd
I'd bet you'd drop 5-7000. But how I would do it, is probably different than some. I'd do the clutch of course, and also I'd go through the over/under while it's out of the tractor. I'm picky about rebuiding components while they are off. What better time? To do the engine top notch would require sleeve/piston kits, valves/guides, and at least injectors, if not pump and turbo as well. See, it can be overwhelming. But, a bad injector could be what has ruined the engine, can ruin the overhaul. Good thing you have a good local guy. That is something that will be good as gold. Oh, on the white, while engine is out and cab is tipped up, pull top tank out and check the steering hoses. Very likely the main hose is leaking, great time to replace it, and the lower section too. Been over 25 years since I worked in a White dealer, but still remember the weak spots lol!
matador
@Ed
The 7040 has the 20 speed on it. As for the White, do you have a rough idea of the parts and labor on giving her “the works”? Out here, there’s one guy who’s a master at everything pretty much. I need to talk with him, but I’m sure you have more of an idea on cost than I do (Heck, I thought you’d need to split the tractor to do it, so I’m way off already) |
TimNearFortWorth
Orange Level Joined: 12 Dec 2009 Points: 2014 |
Urge you to consider putting the money into the White over the winter.
You know and like the tractor and if access to a reputable shop, you will have something you already know works vs. maybe having something else you bring home turn into a money pit, just when you need it most . . . . .
injpumpEd
Yea, you'll want to rebuild the 105 someday. Great little tractors that usually put out closer to 120hp than the rated 105. You don't split a 105, you pull the engine and over/under assembly out of the front frame tub. But, first thing is to pull the long pto shaft out the back lol! The 354 perkins is not an engine for a first timer to rebuild if it needs new sleeves. They are dry sleeves that are in the block tight! We have done a re-ring job on a few customer's tractors over the years, with ok success. The problem seems to be the age causes the rings to lose some tension, therefore lose their sealing ability. This of course is if the pistons themselves are in great condition too.
Oh, a 7040 is a pretty great tractor too. PD I'd guess? Lots of places for oil leaks though. Not much different than the white though lol! Edited by injpumpEd - 07 Nov 2019 at 8:25am |
