HD4 steering clutch? |
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10556 |
Posted: 31 Oct 2019 at 7:03pm |
Who sells new steering clutch flywheels for the HD4? Need two of them.Any help appreciated.Tracy
Randaleky
Silver Level Joined: 17 Aug 2011 Location: belfry, ky. Points: 423 |
I use General Gear and machine in Boise Idaho or Illini Construction in Illinois . Aftermarket from General Gear , is also where I get my brake bands and clutch disc .
Tracy Martin TN
General gear doesn't offer them.Mine are bad, not worth the effort to repair. Was hoping to find new ones. I can make them, but sure don't want to. Thanks Tracy
Edited by Tracy Martin TN - 01 Nov 2019 at 2:26pm |
Randaleky
did you try Illini Construction ? Try Blount in Holboken Georgia . they have good used parts . good prices. sent a pic of your worn out ones please . thanks
Tracy Martin TN
Randal, Kevin at Illini is working on finding some. Most used ones have egged holes and register rings. Thanks Tracy
Randaleky
post a pic . I am not exactly sure what you are referring to .
Tracy Martin TN
Randal, don't have a pic here. It is what the pressure plate pushes the disc against.It is made from cast iron, the brake drum separates fly wheel and pressure plate. Thanks Tracy
Randaleky
do you need both ? I will look at my spare part and take some pics to send .
Rick
Orange Level Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3641 |
Tracy...Just to let you know this, I reline brake bands for the crawler tractors and can rebuild the steering clutches as well. I can usually get about any parts you need, as far as new goes, so please keep me in mind. What you're looking for is probably out there as good used or some NOS somewhere, just getting ahold of the right person is the thing. Rick
Randaleky
uploads/5626/uploads/5626/DSCN0955.JPGDSCN0955.JPGuploads/5626/DSCN0955.JPGgoing to try to figure out how to post pics Tracy.
Tracy Martin TN
Randal, that is the flywheel. Mine has egged holes and register ring on back is worn bad. Thanks Tracy
Randaleky
you mean the top pic is not what you need. the bottom is the pressure plate right. the only thing left is the ring that holds the clutch and plates and the brake band fits around. correct ?
Tracy Martin TN
Randal, yes top pic is correct. Thanks Tracy
Randaleky
I think this one needs cleaning good. never sat grooves or out of round bolt holes. they should be easy to find used in good condition.
Marko
Bronze Level Joined: 24 Mar 2018 Location: Rainier OR Points: 5 |
CLICK HERE FOR DETAILS Email steeringclutch@gmail.com for orders or questions. CONTACT OUR OFFICE at 1-208-342-8911 General Gear and Machine, 733 Desert Wind Rd., Boise, Idaho, 83716 US *All prices are in USD & do not include shipping All prices are for new aftermarket unless stated otherwise All OEM part numbers are for references only Here is a link to a place I found. I also have a Parts machine. Hope this helps. MR |
Rick
Tracy...The pressure plate is exactly what I told you it was...it's the same exact pressure plate that came out of the WD45 diesel and is the original 9 spring pressure plate. I can do those... Rick
Tracy Martin TN
Rick, can you supply the complete pressure plates? Sent you a PM. Thanks Tracy
Rick
Sent you a message, Tracy...
Tracy Martin TN
Rick, sent you pics. Tracy
