Wd engine upgrades |
Author | ||
Onalaska Ben
Bronze Level Joined: 15 Oct 2019 Location: Onalaska washin Points: 16 |
Posted: 15 Oct 2019 at 3:16pm |
Good afternoon all. I'm new to the ac tractors. Got a 51 wd that needs an engine rebuild and wondering what combination of parts would be the best. Not looking for a pulling engine but something I can have fun with and improve the horsepower. I would still like to run pump gas. So far I can't find any ac guys in my area. Any help would be appreciated. Thanks.
Sponsored Links | ||
Orange Level Access Joined: 12 Sep 2009 Points: 19508 |
Many WD's have had changes made to their engines over the last 70 years. Who knows what has already been done to yours?? Won't really know until you carefully tear it apart. Your engine was originally 201 cubic inches ( 4 inch bore x 4 inch stroke) and had compression around 5.5 to 1 (100 psi) if it was a gasoline tractor. The WD-45 replaced the WD and had 1/2" more stroke for 226 cubic inches with 6.5 to 1 (120 psi) compression, a better intake/exhaust manifold, larger carburetor and larger air cleaner for an increase of 10 HP over the 35 HP WD. Checking the serial number behind the carburetor air hose might give you some information.
Onalaska Ben
Serial number is wd285114pa. It's already apart is 4" x 4". It dropped the head off a valve so it needs at least a sleeve rod and piston. Otherwise the engine was in great shape. By the looks of the engine I'd say it doesn't have many hours.
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8167 |
Ben,
Welcome! Cheapest way might be to just repair that one cylinder and have the head totally redone.
Might be in the under $500 zone. Complete rebuild with WD std components set aside $1500. That's if your doing the work. Double that if a good shop is doing the labor. Justy my guess art the costs. WD45 crank and components, add another $500-600. Regards, Chris |
AaronSEIA
Orange Level Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2533 |
Best cheap power add on option is to find a good WD45 crank and use WD45, D17, or 170/175 pistons. Then you'd want the WD45 air cleaner and carb for proper air flow. AaronSEIA
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4388 |
Probably the least expensive power enhancement would be if you can find a set of good used M&W pistons.SP-46 were for the 4" stroke 201 and SP-48 for the 4.5" stroke 226. Both were overbore 4.125" .
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1698 |
To add power without spending a lot of money, ill second Aaron with using a wd45 crankshaft. You could then use the stock 4" bore wd45 (6.6:1), D17 (7.25:1), or 170 (8:1), or 175 (8.25:1) pistons to get anywhere from 45 to 55hp. If you have to get new sleeves also, consider getting the 4 1/8th sleeve piston set with the 7.25:1 comp ratio. Also consider a D17 governor spring instead on the WD one. KEEP in mind: the pto gears are the weakest link when increasing hp from stock on a wd/wd45, so if you plan on using the tractor for pto work, don't go too "balls to the wall"
www.awtractor.com
Alex09(WI)
and WELCOME TO THE FORUM!!!!
www.awtractor.com
Onalaska Ben
If I was to use a farmall h 8.000" rod is there a piston that would have the correct compression height from the later engines that would give me the compression I'm looking for?
WF owner
Why??? I know one of the premier AC guys that builds engines for tractor pulling, used Farmall H rods, but I believe the major reason is for clearance on engines that the stroke has been increased significantly (over 5" stroke). I have never heard of the stock AC rods in a 201 or 226 being a weak link. I think you are wasting your money.
Onalaska Ben
Wasn't worried about strength but was looking for a way to raise compression. I only have 3 good rods at this time so I'll need to get a rod core.
Stan IL&TN
Orange Level Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
I would look for a good running WD45. You will save money and time and get an increase in power.
1957 WD45 dad's first AC
Charlie175
Orange Level Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6351 |
You will need a bigger carb on the WD if you want power.
That little stock one will hold you back.
Charlie
exSW
Orange Level Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Instead of starting a new thread I'll piggyback on this one. How can you tell what mods a WD has had without teardown?
I brought one home and it does run well. The previous owner stated that the engine had been into and warmed up( nearly 50 years ago). It still has the WD manifold and zenith carb(that I've rebuilt). Edited by exSW - 04 Apr 2022 at 6:58pm |
Learning AC...slowly
An honest compression test would possibly reveal something. A regular WD engine will only have about 100 psi of compression. A WD45 will have 120 to 125 psi. A "scope" inserterdf thru a spark plug hole will reveal what the piston head looks like...flat top (WD) or smooth bowl (WD45) or heart shaped bowl (M&W overbore).
exSW
Delete
Edited by exSW - 04 Apr 2022 at 7:13pm |
exSW
Been wanting an excuse to buy a scope.... Plug right into my phone. |
WF owner
50 years ago is about the era that a lot of tractors were rebuilt with M&W sleeves and pistons for increased power.
M&W pistons had a heart shaped top. One way to tell without a teardown would be with a borescope camera. I have one and i love it!
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3284 |
what about the taller wd45 head ?
Late model WD's had the taller head. Improves cooling but no real HP benefit.
Sugarmaker
Thanks(1)
exsw,
Better start a new thread on your work so far on your WD project! We like pictures too! Regards, Chris
exSW
Looks like WD manifold, carb and air cleaner.
exSW
Yep. No confusion here. '52 WD. Runs like a sewing machine. After 25+ years in a shed. |
Phil48ACWC
Silver Level Joined: 17 Jan 2013 Location: Vermont Points: 278 |
I have a good WD-45 Crank Shaft I'd sell. $300 plus shipping. Shipping will be a killer from Central Vermont.
