190 hydraulic leak out of steering column
wf32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wf32 Quote  Post ReplyReply Direct Link To This Post Topic: 190 hydraulic leak out of steering column
    Posted: 08 Oct 2019 at 7:30pm
190 has started to leak hydraulic fluid out of the steering column by the steering wheel what is the cause and how bad to repair
Phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 8:41pm
Need new seals in the steering motor.  After 50 years, they may be a little worn out.  I took mine to my local hydraulic shop 2 years ago and haven't had any problems since.  Just remember to label which hydraulic line goes where.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 8:54pm
Getting steering motor out is biggest problem. Don't pull the shaft out.      MACK
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 9:51pm
You may be able to get by with a front seal kit for the unit.
wf32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wf32 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2019 at 12:04pm
to remove steering motor do you have to take out the whole steering column or can you just get motor out
Phil
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2019 at 2:19pm
Actually the column and shaft is held by 4 bolts to the steering valve. The shaft splines into the valve. The seal is in the top cap of the valve. The valve will have to be removed from the column. The tilt pivot is on the column.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2019 at 10:58pm
Take the top cover off the hood so you can look in and take the right side panels off too so you can reach up in there.  There are four bolts that you take out, the steering column and wheel stay on the tractor. You will have to take the dash gauge panel loose so you can get at some of the bolts from above. You can get a wrench on a couple from underneath..  Like said, don't mix up the hoses.   Once the unit is out  you can change the quad ring and outer seal by removing the 12 point bolts in front casting..
