WD hydraulic pressure |
Nathan (SD)
Orange Level Joined: 11 Sep 2009 Location: Day County SD Points: 1239 |
Posted: 15 Sep 2019 at 10:01pm |
I tapped into the hold valve with a gauge. I used the front port on the clutch pedal side.
The gauge shoots up to 2800-3000 psi when the lift arms top out. Then with the valve handle still in the full up position, the gauge drifts down to about 1800 psi after 10-20 seconds. Is this correct? Or is it a problem? This WD won't lift much on the rear is the reason I even checked it. |
MACK
Should be around 3600, otherwise normal. MACK
John426
Silver Level Joined: 14 Aug 2012 Location: France Points: 271 |
Hi
Interesting, do you an idea what pressure it is for an ED40?
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22807 |
A .010 shim on the unloader spool will bring it right back to original if everything else is right. My 45 is running about the same as yours. I left it, because I was too lazy to take the pump off for the 3rd time to get it back to 3500PSI.
