i40 hydraulic pump |
dieselDonutz
Bronze Level Joined: 03 Aug 2019 Location: Frenchville Pa Points: 3 |
Posted: 03 Aug 2019 at 3:40pm |
Hi, everyone. I am new to the forum. I have spend some serious internet
time trying to find info on the hydraulic pump that is mounted on the
front of the i40's If I didn't know any better, I would guess that this
information is only available to the most secret of agencies that
protect our planet and be sure that the info does not fall into the
wrong hands. (back story) I purchased an old i40 for a great price. I am
trying to restore it. it did not come with the pump on the machine so i
have no reference. every pump I seem to run across is for the farm
tractors and is not the one that mounts to the front of the 149 motor. I
am hoping (desperately) that someone here is laughing right now saying I
know all about that and is willing to help someone that is a bit green
in this area. a picture, a part number, a picture and a part number. I
cant even find a service manual or a parts catalog (that I don't have to
pay for upfront) without knowing if it has any relevant info. any
assistance would be greatly appreciated. and I promise I have no
intentions of destroying the planet when i finally get it powered up!!
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4351 |
Welcome I hope somebody knows. I have experimented before with what I found cheap and learned pressure don't count in making it work if the flow is way low.
We country/redneck/dirt farmers/ the unwashed (take your pick of name,cause I missed some) that are trying to help improve the world with dozers,backhoes and dirt moving even with a shovel. Are considered to be destroying the world by the PC folks..........so remember who your asking for help.
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50529 |
Per swinford's book, the front pump put out 17 GPM @ 2000 PSI for the I-40, 15 GPM, 2250 PSI, for the I-400.
Now all you need to find out, is what the pump mount looks like, how many holes, how far apart, mount circle diameter. Then go to surpluscenter.com's tech pages, and see if you can find a similar mount listed. This will give you another piece of the puzzle. Even If they don't have a pump to fit spec, their page is tops, at describing the naming of the parts. Do you have a shaft hanging out the front, or is that among the missing, too? I think there is also a plate that bolts on the crank pulley, to mount the shaft to.
Jim.ME
Orange Level Joined: 19 Nov 2016 Location: Maine Points: 934 |
Minnpar has a parts catalog for an I40 free for use on their website. They might also be a source for pump info.
Minnpar I40 parts catalog |
dieselDonutz
Thanks so much for all the info. I don't know hydraulics as much as I would like to so I didn't want to just pick a pump without hearing from someone more seasoned. it seems pretty straight foward. one question I do have is if the pump needs to be 17gpm @ 2000. and I find a pump that says for example:
does that mean that it will work since the requirements fall inside the above range? and yes the shaft is coming out of the motor so it looks like I can just mount the pump with a jaw coupler (after I get some clearance, the radiator mount is so close to the shaft that a jaw coupler will rub against it)
