Difficulty starting 5040 |
DJB
Bronze Level Joined: 23 Jun 2019 Location: Gretna Points: 3 |
Posted: 25 Jun 2019 at 12:38pm |
I have an AC5040. During the winter it requires being plugged in but when we went to use it the other day it wouldn't start and we had to plug it in for 2 hours. Is this typical?
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11396 |
I guess that depends on your location.......But at this time of year I'd say that's not typical.
Jim.ME
Orange Level Joined: 19 Nov 2016 Location: Maine Points: 937 |
Gretna: FL, LA, NE, VA, United Kingdom, or none of these?
Doesn't seem like it should need heat this time of year. |
Tbone95
The interesting question is did the heat actually help it, or was it a coincidence that it started after 2 hours of heat???? If the heat helped, then.....poor compression? Seems the logical problem?
Larry in NC
Orange Level Joined: 09 Feb 2016 Location: NC Points: 1041 |
I had a 5040 a few years ago and it normally started fine without heat in warm weather. Heating the oil is a slow process. The tractor has a manifold heater which would be the effective way to heat it when cold oil is not an issue. If your heater is not working, they are cheap to replace.
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2853 |
Those need a good battery to really turn the motor over fast,plus hold the throttle wide open when you're cranking it.Make sure the starter isn't dragging. Also if it starts by plugging it in have you tried the preheat to start it?
wheatbreeder
Orange Level Joined: 12 Sep 2009 Location: Harrow, Ontario Points: 580 |
we had one years ago Gary is correct the need to be spun fast
Farm stuff 8050,6690,175,F2,5050,WD
Dave (NE)
Orange Level Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2104 |
If it is not spinning fast enough, is this a starter issue or the battery not being big enough?
FYI - it is Gretna Nebraska. Has been warm enough that it shouldn't require being plugged in.
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
