Allis 301 |
Post Reply | Page <12 |
Orange Level Access Joined: 12 Sep 2009 Points: 19505 |
The thicker you make the head gasket, the harder it will be to hold. Same as a 1/4" one-wire hydraulic hose versus a 1/2" one-wire hyd hose. The smaller hose will tolerate a lot more pressure before it fails. Cut your piston tops down.
Fullpull
Bronze Level Access Joined: 02 Jun 2019 Location: Canada Points: 50 |
The gasket will be .155" does that seem workable ?
Fullpull
Suggestions on where to get a Allis 175 gas cam grind done on a G262 ?
30 or more years ago, I sent a 175 cam to Berry Cam Lester Prairie, Minnesota for them to copy. I had them do probably a dozen regrinds for me over the years. I understand they are under different ownership now, and have heard maybe they aren't as dependable as they used to be.
Fullpull
Thanks Dr Allis, I will see if I can find a shop with better review.
Robacpuller
Silver Level Joined: 07 Apr 2016 Location: Wisconsin Points: 247 |
Quality performance products in Spencer Wi.
ph. Number 715 659 5152. They did a 4 master grind on my D17 cam. Wi 50 does a lot with them. Give me a P.M. or ur cell number. I will give u a copy of my cam card. |
Fullpull
Thanks Robacpuller,do they have a good return on finished product time line? Do they do head work on AC G262 ?
Robacpuller
Call me at 608 228 4843.
I can fill u in. |
Robacpuller
I can't get my text to go through. I am posting it here.
Fullpull
If I have a allis G262 stock bore flat top pistons, 0.195" from top of piston to top of head,0.175" head gasket, 3.75"bore head gasket what would the compression ratio be?
11.67 to 1 with no valve protrusion.
Fullpull
Thanks DrAllis ,I am wondering with that setup how is it possible to start the engine with a snowmobile battery that has 320 CCA ?
You won't. If that is all you can have for weight, you'll need a jump pack to get it started and disconnect it afterwards. You'll get tired of that after a couple of seasons and get a real battery in it.
Fullpull
We had 700 CCA battery and a 320 CCA we would start it then remove the 700 CCA battery used the 320 battery for our ignition, I stalled it on a pull and restarted with just the 320 battery and that was with the setup with 11.67 to 1.
brad durst
Bronze Level Joined: 20 Aug 2018 Location: richland center Points: 85 |
i have a good running gas 190 engine for sale. its complete 800$ the fan to the pressher plate
Fullpull
Sorry not interested in the 190 engine.
Fullpull
Was thinking someone would have an answer how it was possible to start the motor with 320 CCA battery with 11.67 to 1 compression,I am refreshing the motor now so if I did something incorrect before I would like to fix it.
steve fischer
Orange Level Joined: 11 Jul 2011 Location: sleepy eye mn Points: 927 |
berry cam has two different grinds one is allis number 175 (very hot )the one you want is the model 175 gas grind
Fullpull
Thanks for cam info. Mr Fischer
Why haven't you ran a cranking compression test on this engine??? You should have 240 psi or more, with the throttle wide open, all spark plugs removed and a battery charger on the battery to keep cranking speed fast and consistent.
Fullpull
I have taken the engine apart and will be doing the stuff to it that you talked about and see what results I will get and yes I should done some more testing.
What exactly did you have your ignition timing set at and what octane of gas were you using ?? With 12 to 1 compression, it will require the timing to be LESS than the OEM timing of 25 degrees BTDC @ 2,000 RPM. More like 18 to 20 degrees BTDC and really should be done on a dyno of some type to achieve max power output. Octane rating needs to be 110 or better for best results.
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3238 |
high compression engines are for high rpms - not 1800 rpm luggers. the peak cylinder pressure , unless controlled with octane and timing - as Doc sez on a dyno - will not be kind to internal components .
Fullpull
I was running 114 then 110 octane gas,do not have pto for dyno and running 3000 rpm maybe not a lugger.
And what was the timing set at ?????
Fullpull
I do not remember Dr Allis.
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7981 |
We had a 261 Chevy (big brother to 235) and was notorious for cracking pistons when run above 3000 rpm. Don't know if 235 piston is stronger but you may be asking for trouble.Just saying....
Fullpull
The rpm will be 3000 max. We ran the other setup for 5-6 years at 3000 rpm and pistons look fine.
