Allis G short project |
Richardmo
Orange Level Access Joined: 12 Sep 2009 Location: Rolla mo. Points: 1732 |
Posted: 27 May 2019 at 12:26am |
This Allis G has been a project I have been working on off and on for a couple years. Started out look like this and the loader had been removed. Bought the loader with help from people I know in PA.as it came from PA auction. Today made some adjustments to the length of the loaders arms and will need to weld the pivot points for the cylinders. Edited by Richardmo - 27 May 2019 at 12:31am |
JoeM(GA)
Orange Level Joined: 12 Sep 2009 Location: Cumming,GA Points: 4522 |
Coming along great!
Allis Express North Georgia
B26240
Orange Level Joined: 21 Nov 2009 Location: mn Points: 3860 |
I read an article somewhere that said they used shortened G's with loaders to unload railroad box cars. For-runner of the skid steer loader. Nice job, rare tractor !!
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8167 |
Richard,
You always have interesting Allis projects! This short G and loader will turn some heads. Power steering might be needed with a bucket full of dirt? Looking forward to your updates too. Regards, Chris |
Gerald J.
I have a shop manual that covers the G and a G operator manual and a couple G implement manuals on line:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf http://geraldj.networkiowa.com/Trees/Allis%20Chalmers%20G%20Owners%20Manual%20(TM-4A)0001.pdf http://geraldj.networkiowa.com/Trees/Model%20G%20Implement%20Setup%20(TM-3)%20PART%201.pdf http://geraldj.networkiowa.com/Trees/Model%20G%20Implement%20Setup%20(TM-3)%20PART%202.pdf Gerald J. |
Richardmo
Today work on the making Cylinders for the loader.
The ones that came with the tractor are to far gone to fix. These will not be exactly like the others but close. Was able to cut the back section off the tube, Also drilled out for oil supply and welded a fitting back in. Was able to cut off the shaft and re taper it. |
allis g
Orange Level Joined: 10 Jan 2012 Location: Templeton Points: 402 |
Is that short g something that was built by Allis old did someone else modify it
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50538 |
Maybe here? |
Herb(GA)
Orange Level Access Joined: 15 Sep 2009 Location: United States Points: 1007 |
DiyDave's post tells the story. This unit is great but only for a few uses. My best use is elevated storage in our large shed; also hauling wood chips at our church large, blacktop parking lot. CAUTION is important if your shortened G is operated without the loader; I was told they could easily do wheelies. Herb(GA)
Richardmo
On Sunday welded the brackets on the loader.
Richardmo
Made a bracket to hold the Hydraulic pump.
Used the torch and a grinder to make the cut out. Had to cut out and 1 1/2" of the bracket to allow the pump to be installed and re welded on the other side. Also clean out the tank and mounted the valves on the tractor. The color is wrong and this will be corrected when everything is tested and working order. |
CTuckerNWIL
I think I have that same old drill press in the shed. A guy gave it to me, didn't want it scrapped, so I took it. I've never had a motor hooked to it and the flat belt step pulley is gone off the back, but I do use it for cracking walnuts
CTuckerNWIL
" The initial application was unloading bulk fertilizer from railroad boxcars (as David mentioned); and the immediate market was eastern Iowa."
My Dad worked at AGRICO, in Fulton, Il back in the day(post WWII). It was a bulk fertilizer outfit, just across the river from Clinton,Iowa. I can't ask him anymore, but I would be willing to bet he saw and maybe even used one of these short G's while unloading boxcars. One of the original AC mechanics from the old Albany,Il dealer, is still around, living in Clinton,Iowa. Net time I see him at his shop, I'll have to ask if he ever saw any of these around. Edited by CTuckerNWIL - 08 Jul 2019 at 10:27pm |
Richardmo
Hook up the hydraulic lines today and gave a test run.
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21478 |
that's really neet to see a 'shorty G' ! Wonder how LONG it took to unload a RR car though... and just how SHORT were men back then as I can't see me ( 6-2) on that G ! Jay
allis g
That must have been an adventure just to climb on board.
Alberta Phil
Orange Level Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3652 |
I'd think you want to keep your elbows tucked in tight when operating that loader!! A neat little tractor, never the less. |
chaskaduo
Nice work and very interesting. I'm off and googling now.
