8070 and jd forage harvester |
Author | ||
Tenn allis
Bronze Level Joined: 24 Nov 2016 Location: Tennessee Points: 126 |
Posted: 23 Apr 2019 at 9:01am |
Can you use an 8070 on a jd forage harvester and leave the hydraulics engaged without damaging anything to run the controls
Sponsored Links | ||
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11398 |
I guess I don't follow.....hydraulics "engaged" doing what? And what JD harvester model and what controls?
Orange Level Access Joined: 12 Sep 2009 Points: 19560 |
Adjust the remote lever kick-out so it cannot cancel itself. DO NOT tie the lever engaged with a tarp strap.
Tenn allis
How do I adjust the kick out dr.
Tbone95
OK, I'm out of the technical loop, that's fine. But I'm still curious, hydraulics engaged continuously for what purpose?
Tenn allis
You use hydraulics on the tractor to control the spout and reverse the transmission and swing the tongue on a jd tractor you just lock the lever down to control them they’re electric over hydraulic
Tbone95
So the tongue swing is the one left engaged....OK....thank you.
Tbone95
So you need 3 remotes to chop? Seems a pain.....And....do you really need to keep engaged to keep the tongue swung over? It won't hold in the off position? Or just an occasional bump to keep it over?
Just interested is all. I've never had an implement with a hydraulic hitch swing. I "used" to think it would be handy, now not so sure!
Operators manual shows how to lock detent kick-out. Remove rubber plug at the rear of the valve you want to lock and with a pocket sized flat blade screwdriver (maybe a little bigger than pocket sized) tighten down the screw gently until it just hits bottom.
Count how many turns you changed it so you can back it off to normal kick-out if needed.
Edited by DrAllis - 23 Apr 2019 at 10:58am |
tomstractorsandtoys
Orange Level Access Joined: 11 Feb 2015 Location: wi Points: 515 |
It is going to depend on what tractor that harvester was used on last. If on a 4455 or older you need to change something on the valve on the harvester. If used on 7800's and newer it will have the correct valve. Has to do with open and closed center hyd's. Tom
Tbone95
JD tractors a lot older and smaller than a 4455 still have closed center. Not saying there's not an issue, but there must be more to the story.
Tenn allis
You lock down one lever that gives you hydraulics for all functions there’s a electric control box in cab there’s a set of hydraulic solenoids on the chopper whatever function you push it activates that selenoid and the constant pressure of the hydraulics activates that cylinder pull it with a 4450 which is in shop pulling it right now with 7810 both have closed center hydraulics
Tenn allis
Thanks doc
Tbone95
Oh, OK, cool. I bet it works pretty good.
I've run a Ford (LONG time ago), Several New Hollands, (3 or 4?), and a Hesston. Last couple New Hollands were all electric motors for that stuff.....not the most robust thing in the world. The ol' Ford was all ropes. The Hesston had hydraulics to pivot, a rope for the deflector. The reverser was not hooked up, but that thing worked so awesome you didn't need it.
Oldred
Bronze Level Joined: 21 May 2010 Location: Bluffton,AB,Can Points: 148 |
The JD pull type combines are the same, need a remote lever engaged to run other multiple hydraulic functions from the combine solenoids. I built a lock for mine, but would this cause any damage or unnecessary wear ? If so I will adjust as you described. Also what about an air seeder fan that needs to be engaged all the time as well. Thx Mark Edited by Oldred - 24 Apr 2019 at 11:05am |
If any "self-cancelling" type of remote valve is locked engaged with a tarp strap, there is a 3 to 5 GPM hydraulic LEAK inside the valve causing the oil to heat up more than is necessary. Making the self-cancel feature to not work is the best for your hydraulic system.
Tbone95
For an air seeder fan, there is constant flow. These control circuits only flow when you're actuating something, the rest of the time, there is flow in the pilot trying to kick out the lever.
darrel in ND
Orange Level Joined: 22 Nov 2009 Location: Hebron, ND Points: 8587 |
You might do good to turn the flow control down quite a ways, too. That stuff doesn't need to move 100 miles an hour. Darrel
Oldred
Thx guys,
I will hook the air seeder fan to the remote that can be adjusted for the proper flow which will dictate fan speed. For the combine I will adjust the detent as described above. Mark |
