Winter Projects redux
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Topic: Winter Projects redux
    Posted: 30 Mar 2019 at 9:51pm
As I said before, I would post pictures of the seat we recovered in the 7060. There was practically nothing left of the original vinyl and foam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 10:05pm
These are the brackets I made for the light bars.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 11:01pm
that will be a whole new tractor at night
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 11:05pm
I always see vynal seats in ya'lls tractors, my 7010 came new with a cloth seat. I haven't seen them since on any tractors. optional?
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 7:07am
Mine has cloth also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 8:12am
The 7045 had a cloth insert. It looked olive drab. Don't know if that's correct or if it was that dirty.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 11:09pm
Where is the water going to drain now that you bolted the lights in those holes?
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2019 at 12:07pm
Yeah I know. I did not want to drill new holes for that. I thought about cutting notches in flat washers for a drain opening but the long term goal is to add stadium light brackets.
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2019 at 12:24pm
Where did you get the led light bars at?
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2019 at 3:30pm
Rock Auto. A little over $100 each plus the switch/relay harness. 14000 lumens. Same money as 8 round LED's from Theisens I put on 7045. Will compare light output when I get them side by side after dark.
