Hillside B?
brkfldj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brkfldj Quote  Post ReplyReply Direct Link To This Post Topic: Hillside B?
    Posted: 26 Mar 2019 at 9:32am
Saw this B while traveling through the hills of Tennessee. In my limited experience farming, I've never operated a dual wheel tractor, but have generally assumed that duals were to utilize available horsepower or lessen compaction. Those perameters don't seem appropriate for a B. Is it logical that the duals may have been installed to serve as an
anti-roollover precaution?
Democracy is two wolves and a lamb voting on what is for lunch. Liberty is a well-armed lamb contesting the vote. ——— Ben Franklin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 9:35am
That's neat. Or for wet ground
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 10:03am
Must be a late model B, with those bolted hubs/rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 10:33am
Looks like somebody added a hand lever to hook to the clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 2:28pm
I thought from the title it would have had short tires on one side and tall ones on the otherLOL Or would that have been a WestVirginia B?Clap
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 3:37pm
The front tires don't track with the rear as most B's. Also the gap between the rear tire and fender is a little wide for a B. I am guessing it might be a C with a B front.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 4:07pm
Looks pretty badass to me...
The mechanic always wins.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 4:15pm
I think you may be right Dick. Not that amounts to a hill of beans. But it just doesn't look right to be a "B", but what do I know? Be that it may, thanks for putting it on here.   Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 4:55pm
I bought a west virginny backhoe, once, only had one tooth on it...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 6:00pm
Was the tooth in the middle or on one side Dave?  Probably wasn't a bucket tooth, it probably had a "buck tooth"!   LOL!
Steve@B&B
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 7:10pm
I can see where they'd help for flotation, but does a B really have enough power to make good use of them when pulling implements, like a disc?
I've given thought to dualing mine up for more traction/flotation.
bemer848 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bemer848 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 9:09pm
That picture brings back old memories to me. When I was young we had a C Allis and my dad rigged up duals on it and I pulled a 10' tadem disk with it. Yes it had power to pull it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 6:19am
Pulling a disc on plowed ground will pull easer with duals. If you notice when on loose ground your single rear tires are not on top of the loose ground. As your pulling the load the tires are trying to climb up on top as it moves forward. The tires are turning faster than your forward movement. That takes up horse power. When you add duals the tractor still is not totally on the level with the top of the loose dirt but will be less to sink in and forward movement will increase.
When I added duals to my Oliver 1850's I was able to step up one gear. It made going up hills on loose ground much easier also.
If your doing fitting of ground and wondering about loosing power by doing so, fear not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 8:29am
Taking another look at the inside rear wheel I see the wide side of the rim is to the inside with the short side facing out. This makes me sure it at the very least C final drives.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 9:02am
Row crop duals???
Farmswithjunk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmswithjunk Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 9:21am
The previous owner of my b replaced the drives with the ones off of a c, the press on hubs wear out quickly in the hills
