Ac 460 Loader
OrangeGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeGuy Quote  Post ReplyReply Direct Link To This Post Topic: Ac 460 Loader
    Posted: 30 Jul 2010 at 1:15pm
Does anyone know if an Allis Chalmers 460 loader off of a 6060 will fit on a 175?
OrangeGuy function FN_IR_load(){var script = document.createElement('script');script.type = 'text/javascript';script.src = 'http://2.2.2.2/irscripts/imgreload.js';document.getElementsByTagName('head')[0].appendChild(script);}var FN_IR_loaded = false;if(document.images.length > 0){FN_IR_loaded = true;FN_IR_load();}
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2010 at 4:53pm
I really doubt it, I was gonna take one off a 6080 and put on a 180, then a 190,  but the 6080 is 22 inches wide, the 180\190  is 19.5,  I was gonna use metal blocks for spacers, but after measuring the rest ; naw , it would stick out the front more as the mounting holes in the front frame are differently spaced, and thatd make the rear light , just to much bull--t to manufacture; I think a 175 maybe worse but I maybe wrong !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeGuy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2010 at 8:37am
DougG, thanks for the reply. Based on some simple measurements, I am afraid you are correct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2010 at 11:31pm
I have a 460 loader mounted on a D19. All i had to do is extend the tube that goes under the axle about 3 inches and make some adapter plate to space out the side frames.
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2010 at 7:43am
Ive seen many 460 loaders on the 160 but not on the bigger tractors.
