Monarch 75 Steering Clutches |
MonarchDan
Bronze Level Joined: 16 Aug 2016 Location: St. Marys, KS Points: 28 |
Posted: 07 Mar 2019 at 8:00pm |
I have found a Monarch 75 that probably has stuck steering clutches.
Can anyone tell me if the steering clutches can be removed / repaired by removing the top cover plate? Thank you, Dan
Edited by MonarchDan - 07 Mar 2019 at 11:31pm |
darrel in ND
Orange Level Joined: 22 Nov 2009 Location: Hebron, ND Points: 8583 |
Now a monarch 75 is very old, probably late 20's.....? And VERY,VERY rare? I can't tell you much about the steering clutches on it. I know of a couple of brothers that own one that is pristine, and I thought that they said it was one of only 3 known to exist. I could be wrong, though. Maybe I can get you in contact with them if want. They may be able to help ya out. Darrel
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33639 |
Dan, I might have an instruction book but not available readily at this moment. Carl Jacobs, Darien WI. might have a parts book or repair...His 75 is at Rock River thresherie In the meantime, here is a pic that might give you an idea... |
MonarchDan
I thank you all for the responses.
I am buying this 75 over the phone so I have not seen it ... it rolls and the engine is free but the seller does not know if steering clutches are free ... it has been sitting a long time. I expect to find stuck clutches ... will need tech info on disassembly and repair. THANK YOU Dan Edited by MonarchDan - 08 Mar 2019 at 12:28pm |
MonarchDan
Hello,
One more question ... I am trying to find a serial number list of Monarch 75 tractor production by year. NO LUCK so far. Do any of you gentlemen have Monarch 75 serial number information?? I have found Monarch 50 info ... but not Monarch 75 information. THANKS AGAIN, Dan
HD6GTOM
Good luck with your purchase. I gave up looking for one when I turned 60. Sure hope you can get her and have fun with it.
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4346 |
That goes way back and they, had more time it seems and had not built in some of the ideas that made it come apart easy. But the picture makes it look like maybe you can take one side at a time. As the case does not show from this picture a way to lift steering clutchs and bevel gear all in one the way Cat did it until the late 40's.
Good luck and happy wrenching.
JC-WI
MONARCH Model "F" 10-TON 1926......... 10001 - 10081 1927......... 10082 - 10240 1928......... 10241 - 10250 ALLIS-CHALMERS MFG. COMPANY Monarch Tractors Division Springfield, Ill. Model "F" 75 1928......... 70001 - 70207 1929......... 70208 - 70654 1930......... 70655 - 70984 1931......... 70984 - 71066 1931, Allis Chalmers Model L took the place of the Monarch 75 . the
F 10 TON was open chain drive, when Allis took them over, they upgraded
the finals and encased the chains to run to run them in oil. Early Monarch 75 had a Beaver LeRoi engine in them with a 6 1/2 x 7 engine Later MONARCH 75 had a LeRoi 6 3/4 X 7. drawbar HP 78 Shipping weight 23,600 pounds "F" 10 TON test... |
darrel in ND
Wow! That Monarch D, 6-60 must be a rare bird. Looks awesome. Darrel
tadams(OH)
Orange Level Access Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9640 |
It sure does and I bet it really got the job done
MonarchDan
Thank you very much for the serial number information on the 75's !!
Very much appreciated !! If anyone has knowledge on the removal of steering clutches from a Monarch 75 please share. Can the clutches be removed through the top cover?? Thanks in advance, Dan
JC-WI
just something I found on the web... |
MonarchDan
Very interesting info on the F10.
Thank you very much for sharing... if you have other similar info on these tractors please post as well. I am learning a lot .. much appreciated. Dan
JC-WI
MonarchDan, I got in contact with a fellow that has a repair book, says yes, can be taken out the top but there are things you have to do before you can pull them out.... It will take him a couple days to copy the steering clutch section and send the scans to me and I will send them on to you. Prefer to send them email, can send larger pics that way... You sjut have to provide me with email address.
MonarchDan
Hello JC,
Thank you very much for your willingness to help me. Unfortunately,... at the moment my purchase of the 75 may not fly. I sent the gentleman $1,000 down but now there are issues that will likely stop the deal. Makes me sick but ... time will tell. Says he is returning my deposit but has not happened yet. I would very much like to have the steering clutch information regardless as I am determined to buy a Monarch 75 for nostalgia reasons as soon as I can find a good machine. Please do send the information to me at: dancarolk@gmail.com I will gladly send you or your friend a check for copy expense etc. Just let me know. Thanks again, MonarchDan
JC-WI
MonarchDan, that seems to happen far to often, make a deal, both
agree upon, send a check and all at once the deal is off... That
happen to me too on a Monarch 50. My Monarch 75 with a Wausau model 75 snowplow. Both need a lot of attention...
MonarchDan
Hello JC and all,
BAD NEWS ... be aware and pass this info to friends. It is now March 27. I sent a down payment in the amount of $1,000 on the Monarch 75 to a Clif Spain of Beaverton, Oregon 3/9/2019. He then advised me on 3/12 he could not sell me the tractor but would return my deposit. He has since disappeared and does not answer his telephone. I contacted the police and showed them pics of the tractor and my money transfer. They tell me this is a scam. The theif takes a picture of a rare tractor, then contacts local tractor clubs or collectors saying he has a family tractor for sale. I got taken because this guy had called Roger Amato at the HCEA club and Roger passed on the info believing the story about the 75. I also talked to our local CAT club president who believed the story as well and as I am looking for a 75 ... I immediately sent the down payment. Sad!, Anyway JC .. although my deal fell through, I still hope to find a 75 so if you can send me the service info you mentioned, I will gladly pay you for your expenses. My address is: Dan Kennedy 5330 Sumner Ct. St Marys, KS 66536 |
Lazyts
Orange Level Joined: 05 Feb 2012 Location: Manitoba Points: 627 |
Oh yeah, that sucks. I used to think that business was best done on a "handshake", but have found out the hard way that it doesn't always work anymore.. Here's a 75 at the Manitoba Thresherman's Museum not far from me:
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3734 |
a bad situation no doubt. Im confused as to the phone call from him saying he couldnt sell you the tractor and would return your deposit. Not something a scammer would waste his time with once he has your money. I sold some parts and shipped overseas once, and didnt hear a thing for months, and i figured it was a lost cause. turned out the gentleman had a heart attack and was dealing with recovery issues but i did get paid in the end.
MonarchDan
His call does seem strange but the police are trying to find him ( My local Sheriff Dept. Detective is in contact with Beaverton, OR cops)
Sheriff thinks he called to buy time while he changing his ID info. Sheriff does think they will find him as he went to bank and is on video IDK but it is strange and the way he gained our confidence is a new scheme I have been told. Time will tell for sure! |
jerbob
Orange Level Joined: 07 Aug 2017 Location: Michigan Points: 961 |
I know what you are saying Cal and glad your situation turned out ok. He is doing well I am told. Reminded me to not assume the worse first. |
JC-WI
MonarchDan, sent you a few emails on the steering clutches. |
MonarchDan
Thank you !!
I’ll look for the info. Let me know what I owe you. I want to make things right with you. Have a nice day! Dan |
JC-WI
All I want, is to know that you received the material that I sent to the dancarolk email address ... and able to download and print it off. I down sized and resent info differently when service rejected first email.
Tad Wicks
Orange Level Joined: 27 Mar 2011 Location: Shandon, CA Points: 2160 |
So sad, a guy busts his hump trying to make things happen and all you get is a busted hump and then this guy comes along and takes that from you, ought to be a bounty on him. Tad
MonarchDan
I certainly agree. It is sad and we all need to be careful.
The detective told me it has become a racket ... the devils take a pic of s piece of equipment and claim it is theirs. Get somebody to make a deposit or down payment and then disappear. Help spread the word. This crook first asked me for a deposit of $2500 .. fortunately I said no and we agreed on $1000. Makes me sick bc we used to do business on a handshake. SAD |
