Disc brakes
190xt llss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt llss Quote  Post ReplyReply Direct Link To This Post Topic: Disc brakes
    Posted: 08 Feb 2019 at 7:10pm
Where or who makes hydraulic disc brakes for the 190xt
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 9:01am
Why would you need them?
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 4:07pm
We have always built our own. Buy some calipers and you can find disks made to fit the shaft.
Making A living everyday farming with and working on Allis Equipment
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 4:29pm
They help with grabbing and instantly going out of bounds next set I make will be big truck rotors mounted on backside of hubs with dual callipers
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2019 at 10:12am
If I didn't have to, I still prefer the braking to be done at the bull pinion shaft so as to not  load the OEM final drive any more than it already is. Grabbing and instantly going out of bounds sounds like too much braking power and I would think that could certainly be dealt with to soften it up a little.  There is a point when HP and wheel speed becomes more than the OEM brakes can deal with and you feel like Fred Flintstone dragging his feet on the track.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt llss Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 10:27am
Coming up with pedals master cylinders and calipers is easy enough. I was wanting to know is there anybody that makes a brake disc to put on the bull pinion in place of the stock brakes/housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 4:03pm
Utilize the splined part of the brake drum and bolt a homemade rotor plate to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 4:20pm
Hydraulic disc brakes are easier to modulate than the OEM ball actuated disc brakes.  Redo your differential cross shafts with needle bearings and you won't be needing to use your brakes for steering nearly as much if everything on your tractor is not set up off center.
