"FIXD",,,,???
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: "FIXD",,,,???
    Posted: 06 Feb 2019 at 10:49am
 There's a new product on TV that looks to be something us shade tree'ers might be able to use as a great tool,,,,, The new thingie is called " FIXED" and is bout the size of a match box and plugs into the diagnostic port on cars and trks. Then you upload to your smart phone via USB and the engine, transmission or electrical codes info will transfer to your phone with the recommended repairs,,,,,, If this is a legit tool,,,It will save having to buy those super expensive OBD code readers. Too many times I turn down jobs simply because I don't want to pay what they want for them sobs. The good OBD readers are $300 plus,,,,  This little "FIXD" tool costs $35,,,,and,,,,and,,,you just go right ahead and say it,,Shameless,,LOL
 Has anybody tried one,,??
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 11:57am
nope...me thunks that you already know what you is!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 11:58am
I bought one of them things for my mechanic, he hasn't reported back yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 4:17pm
there must be a PROGRAM on the phone that allows it to talk to the port and also has the DATA ANALYSIS .......... what does the program cost?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 4:28pm
I had computer updated OBD tooling, did not have to need to keep it updated so let it die then sold the machine on fleabay. The machine was basically a handheld PC, it read the parameters, showed the codes and data streams, could even record what a system was doing during a flare or foul up while driving. My cost 1994 $$ $296, newer systems are closer to $600, for the better ones. As to telling you what to fix that is BS. Can tell you a code but then a Pre-loaded pop-up that says change EGR or O2 sensor is not actually diagnosing the problem. These are money grabs for the parts sellers as once a electrical or electronic device is installed, is yours no warranty. A Silica poisoned O2 sensor will code out as bad to the cheap device, a Vacuum leak will trigger as a bad O2 sensor or Manifold Pressure sensor not a leak, that takes a mechanic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 5:56pm
thought they were registered to you and 1 vehicle only - so would only work for you and not anyone else after first use
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 6:06pm
I bought the second cheapest OBD2 reader that HF had, and it reads direct, and can erase codes, comes with a book that has all the codes in it.  also came with a disc, but I never used the disc.  Anyway it cost about 30-35 bucks...Wink
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 10:58pm
Harbor Freights cheapest is now $50 and the next is $95 up here, inflation I guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 7:10am
 Hey Dave,,,which model number is the one you talkin about,,??? I'm interested in one that will read codes AND erase em after,,,,,,?
 Not soundin like the "FIXED" one is gonna make it with this crowd,,,,,LOL
  Thanks for all the commentsClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 7:36am
cheapest OBD2 'tool' is about 6 Canucks !! talks to PC via bluetooth( or smart device). I made my own,hardwired to PC in 2000. Have a $30 handheld to reset the idiot light on the CRV(good O2 sensor..BAD CPU).
scanners are great at telling you a POSSIBLE fault...but can't truly say 'ign coil #5 IS BAD'. They could...but ..won't.
I'd be very,very leary about the phone ap..most aps upload YOUR private data(like GPS,logs,photos,etc.) to 'them'....all legal cuse YOU clicked OK to the Terms of use....
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 10:00am
Ya gets only what yas pay fer
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 10:12am
I was wondering about them also. I have had problems with my Power Stroke and plugged my brothers generic code reader in to find no codes.
 I wouldn't mind paying a little extra for something that can at least point me in the direction of the problem, just don't know how to weed out the BS from the useful.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 10:50am
Got an OBDII reader. Paid about $75 for it. Will read most codes except ABS codes. It has helped me many times to point me in a direction. Sometimes a vage direction and sometimes specific. It think it is pretty darn handy.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 1:29pm
Code readers, that figures....
  Every time I looked at the title - ""FIXD",,,,???" kept wonderin if he was talkin about Hungary or gettin himself... aw, never mind     Wink       LOL
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 2:19pm
Around here one of the auto parts stores will pug in and tell you what the problem is for free.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 8:21am
 That's fine, IF you can get the vehicle to their parking lot. It don't help if the thing won't start and it's sitting in our driveway Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 8:39am
 JC,,,,!!!,,,,,,JC,,,!!!!!poor ole Hungry,,he's ,,,,he's ,,,gosh,,I feel so for him as he ain't ever made any puppies,,,not that I ain't been lookin him for a partner,,,they just ain't any Great Danes around here that I want to mate with him. He is a Fawn colored with the black snout and the candidates have been either black or gray or spotted but none like him,,,guess I shoulda let him,,"try" just once tho,,,,,Wink
  As for me,,,,well,,,,I just come back from my Cardiologist in Lubbock, Tx and he told me,,"You know,,I don't think you are 72,,I think you must be bout 62 or 3,,!! He said everything looked great,,!!  Then I went to go see the other Cardiologist that installed the Defib/PM and "She" told me the exact same thing all the time whilst she was breathin in my ear while SHE was checkin thet thingie,,,Gosh Dang but was she a looker,,,,,They sure make them Texas women something to look at,,,(PS I had her sign my chest right below thet Defibber/Pm),,,,,,,WinkWinkWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 5:14pm
Caution, Ron White dog story, play at your own risk...Wink
[TUBE]FMhXOOuoVR4[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 5:23pm
The cheaper "GENERIC" code readers will normally erase the codes also... CHEAPEST will do most USA cars.. Mid cost will also do EUROPE /Jap made cars... they are a little different for some reason.. More expensive units might also do the ABS codes....... READ what the scanner does BEFORE you buy.. I believe there is a DIESEL version and the GENERIC readers don't work on the DIESEL units.
A simple code would be like PO305 ....... that means "misfire on #5 cylinder.
 that can be a bad coil, bad spark plug, or no fuel injected ..... if you get a SECOND code that might help narrow it down, but otherwise, you just get an IDEA of the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 5:28pm
Here is a GENERIC unit that cost $15...  it will read and erase codes... it SAYS it will do foreign cars in addition to USA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 5:44pm
This is one that cost $100. and in addition to the above, it does ABS, Air Bag , Brake problems, and will capture data at a point in time ( collect 100 input values, etc and display).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 11:57pm
Well SOMEBODY close by PLEASE buy one,,,,,,,,,,I've got this light on in my truck........
bikley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bikley Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 5:22am
I bought two last year for about 80 bucks they work great
Have used on a bunch of different cars and trucks and they will erase the codes
I would recommend them
