Turbo problem |
JohnCO
Posted: 21 Jan 2019 at 7:08pm |
Not the right color of yellow but yellow; I've got a Ford 555B backhoe that had a bad engine. Put a new one in and finally got it all together today after over 2 years of it being down. Put the turbo on and pumped some engine oil in it with a squirt can. When I started it up, it started blubbering oil out the exhaust. I didn't use the original return line which was 1/2" as it walked off somewhere. I put a 3/8" line in place and now wonder if it is allowing oil to back up and blow out the seal. Any thoughts? At least I got the expired sheep planted that my neighbor called me about on Friday-was getting pretty big, hoped he wouldn't explode as I rolled him into the bucket. At least that went right... |
Allis Express participant |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77840 |
if you figure out the area of the inside of the pipe ( pie * radius xx2) , you will find out that the 1/2 inch tube will actually flow almost TWICE as much oil as the 3/8 tube... don't seem like it when you say 3/8 vs 1/2 inch, but doing the AREA inside , you see a BIG difference.. twice the flow is probably Half the back pressure on the seals.
and the 3/8 FITTINGS are probably even worse restriction.
wfmurray
Rule of thumbs. Double the pipe size and increase flow four times.
JohnCO
Thanks guys, guess I'll replace the line and see if it works ok, learn something new everyday!
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29559 |
3/8" line will have 1/4(or less) the cross section drain off capability of that 1/2" tube, Will either need to find a tube or step to such as 3/4" id hose to achieve the same results. Cummins changed from hard tube to hose in the 80's, hose was physically three times the outer diameter of the tubes.
JohnCO
The old tube was 1/2" copper but it is MIA so I used a 3/8" that I had. May prove to be an expensive mistake if the turbo oil seal has blown out.
jerbob
Orange Level Joined: 07 Aug 2017 Location: Michigan Points: 961 |
Good Luck John. |
Seals on turbos are finnicky things, Might be surprised to see it not leak soon as get drain oil away from it.
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4773 |
get a 1/2"(at least) drain line back on and it should eventually dry up. The seals won't "blow" per say, it just floods the turbo with oil it can't get rid of.
Personally I would go to a Hydraulic shop, see if they have any 1/2" Hyd Tubing scrap pieces that could be used for this, can bend in a Conduit bender just fine, copper is soft where could get mushed flat and do same thing.
JohnCO
You guys rock! I replaced the return line with a piece of 5/8" copper tube along with new fittings and it WORKS! No oil coming out the exhaust. Thanks to you all for the advise. |
