2900 or 649 Block? |
KevinON
Orange Level Joined: 07 Dec 2009 Location: Schomberg, ON Points: 786 |
Posted: 07 Jan 2019 at 7:18am |
I'm about to begin a build of a 190XT for a 7000lb Super Light Mod Farm class. 330 cubic inch limit, 2.3 charger, 3100 rpm. I have a 649 block, but was wondering if the 2900 block in the XT will suffice? I wouldn't mind saving the 649 block for a light pro stock motor in the future, should I ever get that far....lol. I will get the rods hardened, etc. Thanks for the input. Cheers.
Orange Level Access Joined: 12 Sep 2009 Points: 19554 |
It would work, but you'll be stuck with the older camshaft driven oil pump if you do. Unless you get creative and get a newer wide front gear crankshaft and make a mounting plate for the crankshaft driven oil pump.
If you get into the 1972 model year or newer, a 200 tractor is still a 2900 but has these newer features. XT's don't.
Edited by DrAllis - 07 Jan 2019 at 7:40am |
KevinON
Thanks Dr. I will likely go with the 7020 block that I have and look for another one for a Light pro motor down the road. Cheers.
MACK
Use a external pump then use either block. MACK
KevinON
Thanks, Mack.
Relayman
Bronze Level Joined: 21 Jan 2011 Location: ECIA Points: 22 |
We are using a 7020 crank-driven oil pump on our two charger LLSS with no issues. We found the 7020 uses gears that are 0.883" wide versus the standard 0.668".
For what it's worth, the AGCO parts website shows 7020's with two oil pumps. The serial number break is 49-15229. I'm guessing after that s/n is the larger capacity oil pump and prior to that s/n was the narrow gears like a 200-7000-7010. Personally, I've set up a couple of tractors with a small 4 GPM pump mounted where the hydraulic pump would normally go. This small pump sucks oil out of the side of the oil pan (internal outlet screen) and pumps engine oil to the steering orbitrol. From the orbitrol oil goes thru a remotely mounted 74027979 A-C engine oil filter and then into the left rear corner of the block into the main oil galley. This way, we are supplementing engine oil flow for the second turbo and piston oil cooling. Also, because this circuit is lower GPM's even at 4500 RPM, the filter never bypasses, so the engine oil is always being filtered, even while going down the track. I have a check valve at the entry to the block to prevent loss of oil pressure if this small second pump ever failed (which it has not). We have never had main or rod bearing problems, going several seasons without changing them. Good quality 15W-40 engine oil is all we have ever used.
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7946 |
Just curious on this last post Dr Allis, the engine oil is used for power steering too ?
Yup. That steering orbitrol doesn't know (or care) what kind of oil is pumped thru it. We have power steering and extra oil volume for engine components. The oil pan was deepened to hold another 6 quarts of engine oil.
bsallis180
Silver Level Joined: 29 Jul 2013 Location: Pennsylvania Points: 207 |
What 4gpm pump was used?
Acllss puller
Bronze Level Joined: 02 Oct 2013 Location: Ny Points: 181 |
Kevin I have gear and crank available think I have the pump too .
The 4 GPM pump we used was from a Northern Hydraulics catalog (Concentric? brand) and cost less than $100. This has been 12 or more years ago, but I think it was rated at 4 GPM @ 3600 RPM's. The power steering doesn't work well until you throttle it up a bit, but with a Crower Glide clutch that is just fine.
Edited by DrAllis - 20 Feb 2019 at 7:13am |
