Front Crankshaft Seal
 Post Reply Post Reply Page  <1234>
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 9:11pm
Don used the 1 1/2 pvc to drive the seal in, not to line up the cover. That's what I assumed anyway. He used the other thing he made to line it up. It's obvious I've haven't installed one either. I understand lining the cover up with the crank. I just don't know why it's necessary. Are the holes in the cover bigger than the bolts? It looks like once all the bolts were in, everything should be lined up perfect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 10:12pm
Ranse,
 Don and others will answer better than me. But there are no dowels to align the cover with the engine block/crank and I think this little bit of extra effort may help keep this seal alive longer on the rotating crank?
My guess without measuring is that the clearance in the holes in the cover allow the seal to be offset by as much as .030 inch off center from the crank. That's a guess. I will wait to see who provides a actual dimension? Maybe when/ if I ever get my WD45 engine back together I will try to measure the possible offset between the crank and timing cover in the area of the seal seat.
I also think that the use of shims under main bearing caps on some WD series engines,was part of the reason to do the alignment of the cover/ seal to the adjustable center of the crank. Again just a guess on my part.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 6:07am
I figured the holes had to be intentionally over sized. Now this my be a dumb question, but why couldn't you put the seal in the cover first? That way you use the seal itself to alien the cover. Just simply slip it on the shaft, install the bolts and tighten. I'm just trying to learn too, a WD or WD45 may be my next AC.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 8:18am
Chris is right about shimming on the mains will change the center line of the engine.  The seal will not line the cover to the crankshaft because the spring in the seal is not strong enough to hold the weight of the cover up. If you had a let's say a D17 gas 226 engine cover off you'd find lining pins on the front of the engine because the engine doesn't use shims. It's just like the governor housing needs to have the gear back-lash set too, the older engines are not like a new engine, the older engines where built to be adjusted was they wear.
Edited by Don(MO) - 09 Jan 2019 at 8:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 8:41pm
Hummm, I dont think I ever set the gear backlash on the governor housing? Something else to learn about!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 8:45am
Don't feel bad Chris most don't know to check them. Call me sometime and I'll help you will the setting of it.
Allis Wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 8:47pm
I also Noticed that the Timing Cover isnt perfectly lined up with the bottom of the engine block. Does this mean that the cover isnt aligned correctly?
WD45
IH Cub Cadet 149,1650,1250
#2 Cart, IH#2 Tiller
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 6:38am
No, but it needs to have the same alignment side to side of the block , the cover can be lower or higher than the block just needs to be the same misalignment on both sides of block. Most of the time it will be about the same alignment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 10:44pm
Don, what are the specs on that PVC tool?  Did you put it into a lathe to make?
No wonder so many of these leak after guys have done a rebuild on them!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 11:05pm
Don, I just thought it could have made some difference but makes sense since we’re looking for the seal to be square not the cover.
WD45
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2019 at 8:48am
This may be a little overkill, the two I've done I used a dial indicator to locate the cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2019 at 10:13am
Doesn't sound like over kill to me! Nice work!
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2019 at 11:10am
I need to do the front crank seal on my D-10 series III. Am I going to have the same problem with it?
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2019 at 2:21pm
Mike, Id rather have a little over kill than an oil leak.
WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2019 at 2:23pm
Dusty, you shouldnt have to pull your timing cover as long as the main seal is the only thing leaking. If you do I believe the D series have lining dowels so you dont have to mess with getting the cover lined up.
WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 11:51pm
So I got the pan back on tonight and managed to get the rear gasket off center. There is more coming out of the back on one side than the other maybe 1/4” difference. Did I screw up and going to have to take it back apart to re center it. If so I would probably need a new gasket set again.
WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 10:36am
Good job getting the pan back on! That rear gasket is fairly wide so it might work and seal Ok as is? Probably only one way to find out. Or you could take a picture and let folks give opinions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 12:06pm
WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 12:08pm
I did end up lowering the back of the pan because I couldn’t get the flywheel cover back into place with the pan up. I tried to get the gasket in a little further but it is in pretty much the same place. So it must be correct. The front I’m not sure of yet.
WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 12:57pm
Sorry for the pictures being so big I post them all from my Iphone they look fine on there but are so big on a computer you cant read them. Why is that?
WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 8:18am
Don, if you come to Hutch this year or Union Grove, we'll let you make a video of setting the backlash on the gov housing...Wink LOL Big smile Clap Clap Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 8:42am
So Ted if I decide make a short one will you film it for me? lol
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 8:45am
Don ,That new PHONE u got ,U can do it yourself. LOL
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 8:50am
Fred, I don't think I can hold this pain in the rear phone with one hand and to the work.CryEmbarrassed
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 2:34pm
 In your camera setting you should be able to change the size of your pictures, I think that is right but don't know for 100% sure that is what my phone is like but I always put them on my decktop and resize them. HTH. Kenny L.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 2:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 2:48pm
these are 600x400 your was 4???x????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 4:20pm
Well,
 Whats the verdict on the seal being out of place? Leave it or re-do it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2019 at 9:27am
Kenny, I don’t see a place where I can change the size when the photo is taken, but that makes sense maybe I will just have to resize them on the computer before posting.
Chris, I had to drop the rear of the pan because I couldn’t get the flywheel cover back on I centered that gasket as best I could. I left the front alone because when I loosened the pan the sealer already seemed like it was cured, so we’ll see what happens. Now waiting on the thermostat bypass hose and fan belt from agco.
WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2019 at 10:01am
Maybe this will be a guide for the install next time you are there.
