Front Crankshaft Seal |
Post Reply | Page <1234> |
Author | ||
Ranse
Orange Level Joined: 11 Mar 2016 Location: Tennessee Points: 773 |
Don used the 1 1/2 pvc to drive the seal in, not to line up the cover. That's what I assumed anyway. He used the other thing he made to line it up. It's obvious I've haven't installed one either. I understand lining the cover up with the crank. I just don't know why it's necessary. Are the holes in the cover bigger than the bolts? It looks like once all the bolts were in, everything should be lined up perfect.
Sponsored Links | ||
Sugarmaker
Ranse,
Don and others will answer better than me. But there are no dowels to align the cover with the engine block/crank and I think this little bit of extra effort may help keep this seal alive longer on the rotating crank? My guess without measuring is that the clearance in the holes in the cover allow the seal to be offset by as much as .030 inch off center from the crank. That's a guess. I will wait to see who provides a actual dimension? Maybe when/ if I ever get my WD45 engine back together I will try to measure the possible offset between the crank and timing cover in the area of the seal seat. I also think that the use of shims under main bearing caps on some WD series engines,was part of the reason to do the alignment of the cover/ seal to the adjustable center of the crank. Again just a guess on my part. Regards, Chris |
Ranse
I figured the holes had to be intentionally over sized. Now this my be a dumb question, but why couldn't you put the seal in the cover first? That way you use the seal itself to alien the cover. Just simply slip it on the shaft, install the bolts and tighten. I'm just trying to learn too, a WD or WD45 may be my next AC.
Don(MO)
Orange Level Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Chris is right about shimming on the mains will change the center line of the engine. The seal will not line the cover to the crankshaft because the spring in the seal is not strong enough to hold the weight of the cover up. If you had a let's say a D17 gas 226 engine cover off you'd find lining pins on the front of the engine because the engine doesn't use shims. It's just like the governor housing needs to have the gear back-lash set too, the older engines are not like a new engine, the older engines where built to be adjusted was they wear.
Edited by Don(MO) - 09 Jan 2019 at 8:20am |
Sugarmaker
Hummm, I dont think I ever set the gear backlash on the governor housing? Something else to learn about!
:) Regards, Chris
Don(MO)
Allis Wd45
Bronze Level Joined: 06 Nov 2017 Location: Washington Points: 165 |
I also Noticed that the Timing Cover isnt perfectly lined up with the bottom of the engine block. Does this mean that the cover isnt aligned correctly?
WD45
IH Cub Cadet 149,1650,1250 #2 Cart, IH#2 Tiller |
Don(MO)
No, but it needs to have the same alignment side to side of the block , the cover can be lower or higher than the block just needs to be the same misalignment on both sides of block. Most of the time it will be about the same alignment.
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18727 |
Don, what are the specs on that PVC tool? Did you put it into a lathe to make?
No wonder so many of these leak after guys have done a rebuild on them!! |
Allis Wd45
Don, I just thought it could have made some difference but makes sense since we’re looking for the seal to be square not the cover.
WD45
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3468 |
This may be a little overkill, the two I've done I used a dial indicator to locate the cover.
Sugarmaker
Doesn't sound like over kill to me! Nice work! Regards, Chris
Dusty MI
I need to do the front crank seal on my D-10 series III. Am I going to have the same problem with it?
Dusty
Allis Wd45
Mike, Id rather have a little over kill than an oil leak.
WD45
Allis Wd45
Dusty, you shouldnt have to pull your timing cover as long as the main seal is the only thing leaking. If you do I believe the D series have lining dowels so you dont have to mess with getting the cover lined up.
WD45
Allis Wd45
So I got the pan back on tonight and managed to get the rear gasket off center. There is more coming out of the back on one side than the other maybe 1/4” difference. Did I screw up and going to have to take it back apart to re center it. If so I would probably need a new gasket set again.
WD45
Sugarmaker
Good job getting the pan back on! That rear gasket is fairly wide so it might work and seal Ok as is? Probably only one way to find out. Or you could take a picture and let folks give opinions?
Regards, Chris
Allis Wd45
WD45
Allis Wd45
I did end up lowering the back of the pan because I couldn’t get the flywheel cover back into place with the pan up. I tried to get the gasket in a little further but it is in pretty much the same place. So it must be correct. The front I’m not sure of yet.
WD45
Allis Wd45
Sorry for the pictures being so big I post them all from my Iphone they look fine on there but are so big on a computer you cant read them. Why is that?
WD45
Ted J
Don(MO)
So Ted if I decide make a short one will you film it for me? lol
Fred in Pa
Orange Level Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9106 |
Don ,That new PHONE u got ,U can do it yourself. LOL
Don(MO)
Fred, I don't think I can hold this pain in the rear phone with one hand and to the work.
Kenny L.
Orange Level Access Joined: 12 Sep 2009 Location: NEIOWA Points: 1225 |
In your camera setting you should be able to change the size of your pictures, I think that is right but don't know for 100% sure that is what my phone is like but I always put them on my decktop and resize them. HTH. Kenny L. |
Kenny L.
Kenny L.
these are 600x400 your was 4???x????
Sugarmaker
Well,
Whats the verdict on the seal being out of place? Leave it or re-do it? Regards, Chris
Allis Wd45
Kenny, I don’t see a place where I can change the size when the photo is taken, but that makes sense maybe I will just have to resize them on the computer before posting.
Chris, I had to drop the rear of the pan because I couldn’t get the flywheel cover back on I centered that gasket as best I could. I left the front alone because when I loosened the pan the sealer already seemed like it was cured, so we’ll see what happens. Now waiting on the thermostat bypass hose and fan belt from agco. |
WD45
Don(MO)
Maybe this will be a guide for the install next time you are there.
