WD-45 Oil Pressure Question/Help
Steve-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 Oil Pressure Question/Help
    Posted: 25 Jul 2010 at 3:27pm
When started, my WD-45 has great oil pressure-----after five minutes of operation it wants to drop down to near zero.  I have found that the top oil filter stem was clogged, so I cleaned it and it still acts the same.  Any suggestions?  Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2010 at 4:21pm
Do you have a good filter. A couple years ago there were a bunch of bad filters made with pleated paper inside and a rubber ring in the bottom center. These should be off the shelves but maybe not. The Fram C159 was the only filter that was never made wrong as far as I know. If the stem was plugged I would think that would increase your pressure. Use a straight weight heavier oil or is it time for new cam, rod and main bearings.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2010 at 6:45pm
Here is the filter info Charlie is talking about.
Don
OrangeFever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2010 at 8:05pm
use a fram C-159 for best results.
