Air Filter on HD16 |
jerbob
Orange Level Joined: 07 Aug 2017 Location: Michigan Points: 961 |
Posted: 16 Dec 2018 at 6:22pm |
Hello friends
Would a K&N Pod filter of sufficient size be able to meet the needs for a HD16?? Just curious. |
Ian Beale
Orange Level Joined: 03 Oct 2011 Location: New South Wales Points: 934 |
IIRC from previous discussion of these it will likely be OK for keeping out big rocks and small birds. Research needed I think before you dive
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29582 |
The answer is no.
To get sufficient air flow and filtration you need a significant in size air cleaner. What you are looking at will suffice for a Coal Throwing pickup truck on a city street but hardly a dirt working high air demand diesel Tractor with roughly twice the Cu In displacement. Finding a replacement air filter from a reasonably sized diesel Truck(five ton or larger) will be the adequate size. If just need replacement elements look to Baldwin Filters suppliers as they generally have to older outdated assemblies. Application Associates supply my needs on my 7G. Edited by DMiller - 17 Dec 2018 at 6:35am |
jerbob
Thank you Ian. I have factory set up and new paper element in canister. I used the K&N pod while stripping and painting air filter and the pod seemed to work pretty well.
Is a will fit jerbob, need to be really cautious when do something as that as it takes but a tablespoon of dirt down an intake to destroy an engine, I have seen that done as a experiment.
jerbob
Thank you DMiller. I suspected that but wanted to have it confirmed by experts in this old iron. I have a new spec filter for replacement on my 16. Had a couple of open seams on the original filter housing repaired and was using s pod filter in the short term. The original filter assembly is repaired and airtight, sanded, primed and painted. Putting back on. Thank you for the input Ian and DMiller. |
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3735 |
i would stay with OEM as well. to much risk imho
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50578 |
Thanks(1)
Once that pod gets some dirt innit, that motor will suck the filter up the pipe, like a dirty sock...
jerbob
Hahahaha, great visual.
Thank you, |
