Henderson Loader2
jk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jk Quote  Post ReplyReply Direct Link To This Post Topic: Henderson Loader2
    Posted: 17 Jul 2010 at 11:56am
i was wondering that the life capcity is on this loader, if anyone knows. thanks jk
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2010 at 5:58pm
I could tell you what I've lifted with it, but I wouldn't recommend it...
jk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jk Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2010 at 6:19pm
i'm just trying to get an idea of what this loader and tractor combo can lift safely
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2010 at 6:41pm
The problem is the B was not made for a loader. The stress you put on the torque tube by lifting lots over long periods of time will eventually show its ware. The loaders were not really made as loaders but more as manure lifts for filling straw laden with muck into spreaders around the barn yards and things of that sort. I think it would be ok with moving snow but I wouldn't be lifting logs or heavy loads with it, even if the loader can handle it. The loader might be able to handle it but the tractor is another story. Make sure you have rear tires filled with fluid AND wheel weights, no matter what or how much you decide to lift. You CAN lift both back wheels off the ground so keep your bucket low when using it. Don't put it over your head like it's capable of doing. You also risk dumping whatever you have backwards and onto your head.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2010 at 6:53pm
Morton has good advice, I restored one and have it on a 39B , It is now retired to show status.
jk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jk Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2010 at 10:11pm
what i would really like to do is take the bucket off and put a snow plow on it. i have a snow plow already. i'm not intending to life very many hevay things with it.
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2010 at 12:07am
Just wondering what type of pump everyone uses to power their Henderson loader?  Mine came without a pump and I find the stock B hydraulics are not really designed for this type of attachment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2010 at 7:42am
All the Henderson loaders, as far as I know, came with the Char Lynn PTO Pump.
jk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jk Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2010 at 7:42am
yeah mine has a char-lynn pump as well
