Tie Rods on 180
zas68359 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zas68359 Quote  Post ReplyReply Direct Link To This Post Topic: Tie Rods on 180
    Posted: 07 Aug 2018 at 4:33pm
I have a 180 and the left tie rod came apart.  I put it back and retightened the clamp but it keeps coming right back out.  Do I need to replace the entire tie rod? on this side?
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2018 at 8:10pm
The clamps on the new ones from China will not hold especially if you put anti seize on them. I always take a grinder and take the clamp off the old one and double clamp the new one
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2018 at 7:20am
You must center the swing arm under the engine and then center both front wheels. If the swing arm isn't centered when the wheels are centered it could pull the tie rod apart when making a hard left turn.
