Vinyl Decal set for D15
mherndon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mherndon Quote  Post ReplyReply Direct Link To This Post Topic: Vinyl Decal set for D15
    Posted: 10 Jun 2018 at 8:34pm
I have a D-15 with serial number 15549.  I assume this is a 1963 made tractor.  I am confused on which decal set should go with this tractor.  I'm not sure, but I think it should be a series II.  It doesn't have series II stickers now.  It has the gear shift with reverse down in the middle between 4th and 2nd I believe.  It has the headlights mounted on the rear fenders.  It is a gas burner and snap coupler.  Is there a set decal for this tractor?  It is 125 miles away from me now, and I don't have any good pics to send yet.  Can anyone help?
D-15, Old dealer in Smithville, TN
Post Options Post Options   Thanks (0) Thanks(0)   Quote mherndon Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2018 at 8:41pm
It does have the oval exhaust stack also.  I was looking at the tractors on tractor data.com and see one like it with the series II decals and headlights on the rear fenders.
Mark
Jk chalmers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2018 at 8:43pm
Sounds to me like a series 2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2018 at 9:12pm
Is it a dry air cleaner? Also is it a start push button? And does it have a rear work light? All series 2 things.... as well
Post Options Post Options   Thanks (0) Thanks(0)   Quote mherndon Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2018 at 12:02pm
Yes, yes and yes on the air cleaner, push start and rear work light. Must have put wrong stickers on sometime in the past.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mherndon Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2018 at 12:29pm
Thanks!
