Invasive brush problem |
Post Reply | Page 12> |
Pat the Plumber CIL
Orange Level Joined: 11 Sep 2009 Location: Springfield,Il Points: 4679 |
Posted: 17 Apr 2018 at 1:24pm |
A good friend of mine has 80 acres in the western part of the state he let's me hunt and play with my AC stuff on .He has a terrible invasive bush epidemic that is taking over his forest. We have been waging war with weed eaters set up with sawblades. We wear backpack sprayers and spray the stump immediately after cutting. Question is what is the most cost effective herbicide to spray on the stumps. We have been using brush and shrubherbicide killer from farm store but 35 bucks for a gallon that mixes with 4 gallons diesel. Is there cheaper effective product? 5 acres in 2 weekends 75 more to go
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3735 |
iv had good luck with crossbow and diesel
TDF
Bronze Level Joined: 22 Oct 2015 Location: Seward, NE Points: 62 |
Tordon applied with a paint brush right on the freshly cut stump is my go to.
Stan IL&TN
Orange Level Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Agree with Cal and TDF. Crossbow on woody plants/brush/trees and Tordon on fresh cut stumps.
1957 WD45 dad's first AC
allisrutledge
Orange Level Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1352 |
Use a surfactant with anything you use on brush for adhesion to the plant foilage . I've had good luck with crossbow as well but I think Remedy ultra is better but it cost more.you get better kills when the plant is not stressed. And timing is important as well. Check with your county agent,if you got one.
tadams(OH)
Orange Level Access Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9654 |
Tordon works best
Amos
Orange Level Joined: 11 Sep 2009 Location: Ontario Points: 1301 |
We paint glyphosate right on the stump, sometimes we pour it on right out of the jug when fresh cut. Kills willows even!
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50547 |
X2 on the Roundup, and applying it right after the cut. Roundup can be painted on full strength(41%A.I.) or diluted to half strength(20.5%A.I.).
Problem with tordon, and the broadleaf killers is, that they can transfer through root knots, to other non-target trees, and kill them, too. What is the name of the invasive tree/brush?
Edited by DiyDave - 17 Apr 2018 at 5:41pm |
michaelwis
Orange Level Joined: 12 Sep 2009 Location: Wi Points: 8765 |
My Ag supplier also got me some Crossbow
Edited by michaelwis - 17 Apr 2018 at 5:53pm |
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60 GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
TDF
I've heard that and from many very reputable sources but I've never experienced it. I even used it to kill 6 inch diameter trees I cut out of a lilac bush line around my old house, and never lost a lilac. Maybe I'm just lucky but I've used it so many times over the last 15 years and never had a problem that I'm starting to think conditions must have to be perfect for that to occur. TDF |
BGE(barely getting electric) "spot" applied it a coupla years ago, on a steep hill, under PL ROW, it killed everything, and the hill eroded severely...
omahagreg
Orange Level Access Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2799 |
A tree service, distant relative, told me to use table salt-if you are not in a hurry! Drill 1/4" holes and pour! I did it to an 18" stump one summer, had to keep adding soil for 5 years as the roots kept rotting!
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
If you wanna burn the stumps, use potassium nitrate, drill 1" holes, 4-5" deep, fer medium (18-24") stumps, cork the holes, and in a year or 2, the stump will burn out pretty good, just pour some diesel on 'em, to get started...
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21483 |
'greenies' roundup... vinegar,salt and dish soap. Apply at early morning, plants will wither early afternoon. jug of vinegar, cup of salt,2 capfuls of dishsoap. spray all the leaves , BOTTOMS and tops.
hay, it's cheap enough to try ! It worked for me a few times I needed something. |
farmboy520
Orange Level Access Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |
Tordon
Pat the Plumber CIL
Russian olive,multi flora,hedge are the worst. Wild rose,usual sticker bushes and vines. Problem with Tordon is comes full strength,expensive and has to be dabbed or dripped onto stump or stub. Looking to use backpack sprayer . Can cut and spray right away easy without bending over to apply. Also sticker bushes need sprayed. We have a lot of ground to cover and need to work as efficient as we can .Thanks for all the responses
truckerfarmer
Orange Level Access Joined: 26 Jan 2013 Location: Watertown, SD Points: 3179 |
X2 about the Tordon. I have my commercial applicators license and have used it on the job. If you want to kill everything, use Tordon. If you plan to leave certain trees, might want to find something else. |
shameless dude
roundup can/will also kill other trees that the roots are inter-mingled with. tordon works best, put on as soon as you put your saw down. I buy a spray bottle and hook the trigger on my pants pocket, then with a small reach can spray the stump without setting my saw down to treat it.
Dave H
Orange Level Joined: 11 Sep 2009 Location: Central IL Points: 3477 |
Pat, have you thought about a two phase approach.
Spry the small stuff this summer early After it leafs out. Then move in next yer or whenever and do the stuff that is large and has to be cut down. BTW, i have not had an occasion when tordon or round up transferred to adjacent plants through root systems. |
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3894 |
We had after able brush problem. Borrowed 20 cow from my brother and put them loose on 40 acres in 2 months they had it all cleaned up.
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29549 |
There is an alternate material IF you can get it sprayed on the entire bush(close to ground or get the sprayer over)
. We use it here for controlling saplings of locust and multiflora. Mix as per instructions to gallons of water in a tank, Crossbow, 2-4-D and Tordon(can use RTU just use a entire bottle to a 250 gallon sprayer). Spray when the shrubbery is in a growth stage, not during excess dry or late fall but as greening up, will be dead in a month and will NOT come back. Will not affect grasses. |
shameless dude
lots of times while planting, i'd be planting on the edge of thenfields, when i'd come across a branch sticking out, i'd cut it off, spray the stub with tordon, and by end of summer that whole tree would be dead or dying. that was on trees that were 30-40 ft tall and smaller in size.
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41211 |
Now if you have a skid loader or 3 point - sons brush puller works great - removes plant and roots - .
CAL(KS)
pffft. must not be hedge (osage orange). those suckers are hard to kill
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77830 |
Crossbow is 35% 2-4-D and 16% 3-5-6-T.
2-4-D is a LOT cheaper and will work on many smaller brush if you cut them and dab onto the stumps... If your looking for BULK material and LOWER cost.
mdm1
Orange Level Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2593 |
Do you happen to have a state or county forestry dept? In WI there are some cost sharing programs to eliminate invasive vegetation. Our foresters are very good to work with and are very helpful as far as knowledge goes.
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2206 |
Tordon comes RTU so it's ready to go right out of the jug. thanks; ac fleet
CaseyCreek
Silver Level Joined: 03 Apr 2011 Location: L.A. Points: 332 |
How big is the brush? Any pictures? Is it small enough to mow with a rotary cutter? Mowing would give you the opening/exposure you need into the plant per Shameless. Then you could use a boom sprayer to hit the whole field at once. The mowing would also mulch up lots of the brush. |
D17 Series III,D17 Series IV, 185
Some of the invasive brush have green leaves up toward the end of the year, where other "trees" loose their leaves in October...... In Illinois there is a state program to "spray" the wooded areas of some counties in early December using crop duster air planes.. The spray gets on the invasive leaves and kills the brush... hopefully the trees are not effected since no leaves............. son had that done 2-3 years ago... seem to help over 60%. |
Pat the Plumber CIL
They are like small trees 1 inch to 2 inches diameter at the base . The property is mostly mature woods Walnuts,white ,black and red oaks. Hilly with creeks running through it. Too dense to mow or spray with larger equipment. More than one type of tree,Bush taking over. Trying to clean up the thorny stuff while we are at it . The state DNR sent out a district forest manager and he set my friend up in a program to manage the timber. Basically logging off mature trees every 15 years. If we control/eliminate the invasive stuff my friend gets a tax credit for the timber he sells. Also we are trying to open up the timber where we can see better for hunting. The brush and small stuff took over the last few years. A severe ice storm a few years ago coincided about the same time as the brush took off. When I first started hunting over there 20 years ago it was much more open under the canopy above. Now you can hardly walk through.
