301 valve springs |
goomer
Bronze Level Joined: 18 Feb 2016 Location: wi Points: 48 |
Posted: 19 Feb 2018 at 10:10pm |
Wondering if there is something better than stock valve springs for 301 3000rpm A-pump s200 turbo?
Orange Level Access Joined: 12 Sep 2009 Points: 19547 |
I've never seen a need for anything more under those numbers. Never seen valve float at 3500 RPM with stock springs either.
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4773 |
The problem we've run in to, is boost pressure will try to open the valves between cycles. For that reason, we've set up to use BBC springs, for a solid lifter cam, and even roller cam springs to try to keep things sealed up. The place I get them from is not far from you Brian, Competition Products.
Beirnesy
Orange Level Joined: 30 Jun 2012 Location: Mid Western Ont Points: 351 |
I will be using these springs. They fit perfectly with no alterations and have a closed spring pressure of 100 lbs.
Edited by Beirnesy - 20 Apr 2019 at 9:49pm |
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
injpumpEd
I use the BBC retainer, locks, and rotator eliminators to sit on the head to cover the counterbore.
Peterson
Orange Level Joined: 05 Mar 2011 Location: Westboro, Wi Points: 862 |
My machinist used his BBC spring pocket cutter on my 426 head. Worked perfect. Using comp cams 26120 springs with corresponding retainers and locks. Installed spring pressure is 80 lbs.
Acllss puller
Bronze Level Joined: 02 Oct 2013 Location: Ny Points: 181 |
I have heavy duty springs left off my twin charger set up ! $50 buys plus shipping , good set didn't float at 100 boost and 4800 rpm! Maybe overkill ! Lol
Ryan59
Silver Level Joined: 30 May 2016 Location: Kansas Points: 68 |
Oh my gosh. Don’t You know stock springs were used for decades and engineers hammered out the correct springs with tree limbs. Think of the wear!!!! 85 pounds of installed height will push the cam through the oil pan. Figure 8x80 equals 640lbs of lard setting on that camshaft. Why I was told on here that the big boys take ink pens apart and use the tiny spring in them for valve springs. These guys scared the life out of me just for thinking about 65lb seat pressure springs. Imagine if I had wrote big block springs.....
bsallis180
Silver Level Joined: 29 Jul 2013 Location: Pennsylvania Points: 207 |
That’s pretty interesting. You have any pictures?
MACK
What ever you do don't use stock retainers and keepers. MACK
