D17 Wiring?
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Topic: D17 Wiring?
    Posted: 05 Jul 2010 at 8:57am
Is there just 2 wires on the amp gauge on a 1958 D17 gas,1 to the voltage reg.and 1 to the starter solenoid?If so why don't it show discharge when you turn the ignition switch and lites on?
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 9:27am
Could be a bad gauge, is it showing a charge?
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 10:33am
New gauge,didn't start it,workin on fuel tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 11:05am
The ammeter must be between the battery and all electrical loads except the starter motor. The ammeter is there to show when current is flowing into and out of the battery. It depends on which polarity is used for ground as to which terminal on the meter goes toward the "hot" side of the battery. One terminal will go to the hot side of the battery and all loads, except for the starter motor, including the generator, are connected to the other side. Make sense?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 11:09am
Manual shows 1 wire goin to starter solenoid,other wire goin to voltage reg.,wonder if voltage reg.is bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 11:28am
The only way you will know if the voltage regulator were bad is if it won't charge and all other parts test good.
I'm looking at a schematic of a D17 and it looks like they have the ignition switch on the generator/load side of the ammeter. The lights and ignition switch have to draw current through the meter when the generator is not charging. The meter has one wire coming from the battery side of the starter solenoid. The ignition switch and everything else is connected to the other side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 11:33am
The late D17 has a wire from starter switch to amp gauge,but early D17 don't show that wire?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 11:35am
Just started the motor,gauge don't move.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 11:47am
Does the voltage reg.have to be grounded?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 11:56am
Correction,there is another wire supposed to go from amp to fuse then lite switch,this thing has been cobbled somewhat!!
