Powermax Hydro Rebuild |
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3475 |
Posted: 06 Jan 2018 at 5:35pm |
I've got a line on a Simplicity Powermax not sure which model exactly, but it's the same as a 720. It has a bad hydro in it, how much would it cost roughly to get this thing overhauled?
ac720nut
Orange Level Joined: 09 Feb 2016 Location: Dexter Mi Points: 1217 |
I don't know the exact cost but finding the parts would be the big thing. A gentleman from Canada just recently did one and has it documented on here.
IBWD MIke
I seem to remember that thread. Thanks for the reply.
orangeman
Orange Level Joined: 12 Sep 2009 Points: 1695 |
IBWD Mike: I think if you do a search using Rustydollar that will bring you a wealth of information on the hydro rebuild that he tackled.
Lots of good information and much can be learned through the work that he did and was kind enough to post. Orangeman
IBWD MIke
Ok, next question. I have done business with the potential seller a couple of times already, great guy. I don't want to insult him on an offer but don't want to overpay for this thing either. What's a fair price for a good running (original Onan) Powermax with a bad hydro? Has great tires on the back fronts aren't much.
Brian S(NY)
Orange Level Joined: 13 Sep 2009 Location: CherryValley,NY Points: 3371 |
is it complete with front and rear pto? does it have the three point hitch?
any attachments?
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4669 |
Before you assume hydro is bad I would at least verify oil level by unscrewing the stick to check. How fresh of a filter and oil? My 720 would barely move when I first ran it as it had been setting for awhile before I purchased it. New oil and filter resolved it. Those things are fairly bullet proof if proper care is given. Has it been professionally diagnosed?
IBWD MIke
I will have to get back with the seller in the spring as he has went South for the winter. I'm pretty sure the oil level and filter are good. He is a good AC man. If it was something simple I think he would have caught it.
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4786 |
I had the hydro "go out" on my 720 about 10 years ago. I pulled it out and apart, and all that was wrong was the roll pin that connects the shift lever to the swash plate had sheared off from years of back and forth use. I was able to get all the seals, gaskets and needle bearings, and pins from a Simplicity dealer. The pump group looked really nice and clean still, though the charge pump was a little rough, and it was very expensive, so I just re-used mine. When using it hard, it does get slow to lift when really hot, but it still moves and raises the deck ok. The charge pump provides the hydraulics for the lift.I run Dexron in mine, just like called for in owner's manual.
IBWD MIke
Thanks Ed, I hope I can get this thing bought. After getting my 720 last year and using the front blade I would like to have one tractor for that and one for the mower deck.
Edited by IBWD MIke - 13 Jan 2018 at 12:07pm |
rustydollar
Orange Level Joined: 07 Aug 2017 Location: Manitoba Points: 456 |
Deleted by author Edited by rustydollar - 16 Jan 2018 at 3:10am |
IBWD MIke
Thanks, if I get this thing bought in the spring it will be interesting to see what's actually wrong with it.
rustydollar
Deleted by author
IBWD MIke
Good info, thanks.
bill(soh)
Bronze Level Joined: 13 Sep 2009 Location: waverly ohio Points: 23 |
I have 620 mower that just stopped moving, figured hydro went out. To make a long story short finely figured out all splines on stub axel were worn clear off one side.
D-15,CA,I-400,C,180 2-620's,2-110's,112,718,716,
5015, agco 1718 |
