Tire Presure |
Stroud65
Silver Level Joined: 04 Jan 2016 Location: Farmington, MO Points: 54 |
Posted: 03 Sep 2016 at 8:24am |
I'm running a set of 18.4-38 Firestone radials on my 7000 Allis and I'm wandering what presure I should be running in them. I've been pulling 8500 and 9000lb classes.
Thanks, Matt |
dawntreader74
Orange Level Joined: 28 Oct 2013 Location: Manteno Points: 1758 |
are they cut tires or not cut
zulawski87
Silver Level Joined: 28 Apr 2014 Location: Foley, MN Points: 85 |
I would say 10 to 13 pounds. Radial will squat and flex a lot easier than a bias tire
Orange Level Access Joined: 12 Sep 2009 Points: 19563 |
Tire pressure for pulling depends on a lot of things.....rim width.....tire lug bar wear or type of cut.....ply rating.....tractor weight.....tire brand.....etc,etc, etc. The correct pressure is what puts you down the track the farthest !! I've run a couple of sets of B.F. Goodrich 20.8 x 38 radials over the years at 25 psi in the 11,000 and up classes on 18 inch rims.
Stroud65
Non cut tires. There's not much lug on them. Ran 20psi today at a pull and didn't feel like I hooked up very good. I think it's time to drop the presure
rowcropmafia
Orange Level Joined: 11 Sep 2009 Location: illinois Points: 208 |
I would think you would want to be at or a little under 15lbs i usually run 8-12 psi at 6500lb radials
