Resistor or Not with MSD coil wd45 |
TennMatt1
Bronze Level Joined: 12 Oct 2015 Location: Southern KY Points: 71 |
Posted: 02 Nov 2015 at 7:44pm |
As I was re-routing wires I turned my coil and its actually a flamethower fom pertronix. It's a 1.5 ohm coil so that would explain the resistor.
bigcountry48
Orange Level Joined: 28 Aug 2011 Location: Georgia Points: 1099 |
Oh ok, petronix website says all the petronix systems have multi spark triggers. I must have read that wrong.
http://pertronix.com/prod/ig/ignitor/ |
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3746 |
only the ignitor 3 is multiple spark capable. a regular pertronix ignitor is just a magnetic switch that will not wear like points, but does have other benefits. it is trigger capable for a capacative discharge ignition that can create multiple sparks like a MSD box.
MS ignitions are usually not allowed in near stock pulling like NATPA div 1,2
bigcountry48
The petronix system creates the multi spark, the coil just works with it.
Mrgoodwrench
Orange Level Joined: 03 Apr 2011 Location: CHICORA PA Points: 2081 |
A msd coil alone will not put out multiple sparks, that would take a msd "box". Their coils are just high voltage coils. I'm not knowledgeable enough to say whether or not the extra voltage is useful.
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
bigcountry48
sorry, didn't mean to disagree with you. But like they say at every tractor pull drivers meeting I've ever been to, we all came as friends so let's make sure we all leave as friends! Just make sure that old nasty beat up coil isn't on there when it's done, they don't look to good on those nice pretty pulling tractors!
Edited by bigcountry48 - 30 Oct 2015 at 8:24pm |
Dnoym N. S. Can.
Orange Level Access Joined: 03 Oct 2009 Points: 544 |
thanks bigcountry48
so that would mean that multiple sparks improved idle stability and low speed operation with engines having radical aftermarket cams or even with stock cams. Multiple sparks can lessen problems with misfire at idle. but i don`t think that the msd blaster 2 coil is a Multiple sparks coil ?? B:-) Dnoym Edited by Dnoym N. S. Can. - 30 Oct 2015 at 6:36pm |
bigcountry48
Msd coil puts out multiple Sparks, it helps to fully burn all the gas in the cylinder thus making it run better. It doesn't just make a higher voltage spark.
Dnoym N. S. Can.
I don`t understand why people want a bigger
coil they don`t give more spark unless there a problem a coil only put out the amount of spark that it take to over come the resists of the system it capable of giving more but it just stay in the coil and don`t do noting IMHO B:-) Dnoym |
CAL(KS)
ohms of resistance in the ignition coil. without going into electrical theory, 8 cylinder engines require different ohms than 4-6 cylinder engines or the pertronix module could be damaged. you can check the pertronix instructions online
here also coils are classified for inductive discharge or capacitive discharge ignition systems straight from pertronix.... 1. The Ignitor is designed for 12-Volt negative ground systems. 2. Leaving the ignition “ON” with the engine “OFF” for an extended period could result in permanent damage to the Ignitor. 3. See Chart on back page for coil recommendations. 4. Four & Six cylinder engines require a minimum of 3.0 ohms of primary resistance. Do not remove resistors if the coil primary resistance is less than 3.0 ohms. 5. If your Ignition coil has the recommended primary resistance, remove or bypass all external resistors. 6. The Ignitor is compatible as a trigger for most electronic boxes. Edited by CAL(KS) - 30 Oct 2015 at 8:08am |
TennMatt1
Please elaborate on that please. Why does it matter on the ohms? I understand most of it but I would think since it was converted to 12v and has a alternator that I wouldnt need a resistor.Doesnt it cut back my voltage ?? And if so wouldnt it fire better at 12v??
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11570 |
If you still have the 45' engine in it, you need 2.7-3.3 Ohms of resistance in the Ignition circuit. Make sure that Blaster coil is within that spec. 3.0 Ohm is ideal. I would make a phone call to Pertronix and ask them. They'll tell ya what you need and what will work. Its very easy to burn up a module...
Steve@B&B |
TennMatt1
I have pertronix igniter module in my wd45 and it has the stock coil. I just went and bought a msd blaster 2 coil for it but the old one has a resistor on the outside of it. Do I need to keep that or not? Tractor is already 12v negative ground. Thanks for the help in advance.
