Sleeve hitch and idler pulleys |
irlbeck A-C'S
Orange Level Joined: 28 Sep 2009 Location: Crestview FL. Points: 684 |
Posted: 26 Mar 2015 at 8:55pm |
I'm looking for a sleeve hitch assembly and the rear idler pulleys so i can mount a tiller and a plow to my 916 Allis. Thanks Craig.
B,C,CA,(2)WC's,(4)WD's,(2) WD45'S, 45Diesel, (2)D12'S Series 2, D12 Hiclear,(2)D12 Series 3, HD3, D17NF (3)D17 Series 4 Diesels, M-100 Grader,8550,A few Lawn tractors lots of other AC stuff
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2218 |
You can make the sleeve hitch quite easily or have welder make you one.---the pulley unit I am not sure, but one might be able to make one of them too.---would have to look at my 917-H and see how the pulley set-up is made! thanks; ac fleet
ACmowerguy
Orange Level Joined: 20 Apr 2010 Location: Winfield, MO Points: 1199 |
You don't need a "sleeve hitch" for the tiller. You need the optional rear lift kit. A sleeve hitch is a "one-point" hitch made for lifting a brinly plow, disk, or similar. I will try to post pics later.
irlbeck A-C'S
Thanks for the info. This is the tiller i would like to mount. I thought it hooked up in a sleeve hitch. I have a AC plow as well and i was thinking it will connect in the hitch the same way the tiller does. |
ACmowerguy
Well I didn't read your post close enough and only saw the part about the tiller. My bad. The tiller only requires rear lift as the lower part of the hitch is built into the tiller. The moldboard plow does require a sleeve hitch.
You can download the attachment manuals at this site: http://www.simplicitymfg.com/us/en/support The MFR# for the tiller is 1690039 The MFR# for the rear lift is 1690404 The sleeve hitch is found in the sovereign attachments manual at : http://bsintek.basco.com/BriggsDocumentDisplay/jgEDGP_byN1tG_Exj7mRgtLvBCd6.pdf The sleeve hitch (one point hitch) is on page 6 of the PDF. I have pics but have used up all of my storage space on this site so I guess I will have to find another way to post pics..... Edited by ACmowerguy - 27 Mar 2015 at 10:35pm |
ac fleet
My plow for the 917 is a Brinley 10" bottom, as is the cultivator and both MUST hook to a sleeve hitch,---mine came with a new sleeve hitch in the deal! thanks; ac fleet
irlbeck A-C'S
Thanks for the info. One other question would the sleeve hitch and idler pulleys off of a 300 series work on the 900 series. I have a couple leads on some tractors that may have the parts i need. I'm gonna check the part numbers and see if they may be the same. Just thought some of you guys would know if they are.
