426 camshaft |
NEVER green
Orange Level Access Joined: 28 Feb 2013 Location: MN. Points: 6541 |
Posted: 19 Mar 2015 at 8:40am |
Just had my 426 camshaft reground for higher lift and longer duration by Colt cams. This was his first performance Allis cam. For all you pullers out there the exhaust side is very inefficient, bad lift and duration. He said intake was little better. By improving the exh it will spool up turbo much better.
Since Colt put lot of development in cam he's looking for more business.
Peterson
Orange Level Joined: 05 Mar 2011 Location: Westboro, Wi Points: 862 |
How much was the regrind?
AC 7060
Bronze Level Joined: 06 Jul 2010 Points: 144 |
I also might be interested in a cam how much and what rpm range is it designed for
NEVER green
375.00 for regrind, 108.00 for resurfacing 12 tappets. The cam is for 3000-4000 rpms. If you go to Colt cams web sight there is little more info.
Peterson
I would suppose you have to cut the pistons for valve clearance? Correct?or?
NEVER green
Not sure about clearance, didnt go with huge lift to keep lugging ability, but Im going to check with playdo any way.
Peterson
Yeah I'd be really interested in seeing if it clears. I wonder if he could go alittle milder on profile for a farm/pulling tractor. Hmmmm...
NEVER green
You could call him, very nice informative guy.
Peterson
Any update on this? Just curious.
O.P.S. Heads
Orange Level Access Joined: 02 Jan 2013 Location: Iowa Points: 574 |
It is more than just lift that affects the piston to valve clearance. Durations and event timing have to be considered. If the reground cam has more duration and more lift than a stock cam I would guess you will need to machine the pistons for clearance. There wasn't much room with a factory cam in it.
Edited by O.P.S. Heads - 21 May 2015 at 8:03am |
NEVER green
Stupid farming, planting done, still picking rocks, in process of removing front of engine, will let you know. Soon???????
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7946 |
I always wondered how you get a 301 diesel to run good at 3000 rpm limits , I kno they run real good at 4500 rpm,s ; someone told me get the cam reground- cheap power
NEVER green
Still not done picking rocks, but I did check those clearances. Intake at 090, Ex at 045, I noticed when I set the lash sure had tighten up the Ex lots more. Ive read for 6000 rpm motor clearance should be 080, would 060 work for 4000 rpm motor, thoughts?
NEVER green
Yes duration was increased, especially Ex.
Peterson
Any updates?
moblie120
Bronze Level Joined: 25 Aug 2015 Location: shanghai Points: 2 |
the exhaust side is very inefficient, bad lift and duration.meizu m2 note
NEVER green
Whats the deal with machinists?, are they all slow? Still waiting on my heads and block.
Peterson
Anything yet?
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3245 |
IT would be neat for a cam mfg / grinder to do baseline tests with the old stock cam designed in the 60s for a naturally aspirated engine as in the 3400 and 2800 engines to see what the difference if any would be with a modern grind in the field use engines. If the change is significant, what a business one might have...
Peterson
I think there would be a nice gain in the torque of the engine, plus run cooler too!
Edited by peterson - 09 Jan 2016 at 7:37am |
NEVER green
Sigh, machinists latest is a death in his family, cant complain to him about that. Hope to have it running by spring????
Big Orange
Silver Level Joined: 11 Sep 2009 Points: 313 |
A cam. grinding co. spec. is one thing, but the timing of the cam. in your engine,is another thing. The tolerances of the key ways in crank gears and cams gears, even the key slots in the crank & cam has an effect on timing. In my experience I have found the timing to very as much as 7 degrees, even on stock engines. That will make a lot of difference in the way an engine performs. So check the timing to make sure it's to spec. or advance it to gain low rpm power, retard for high rpm power. But always check the valve to piston Clarence.
Big Orange
You may be able to gain what you need by advancing the stock cam, about 8 degrees with offset key & installing stiffer valve springs, most importantly 1.75:1 rocker arms, as the stock rocker arms are 1.48:1 + stronger pushrods. But be sure to check the valve to piston clearance. The rocket arms & pushrods can be bought from Murphy's Machine in Hallsville Mo. 573 696 3655 or Kenney's Pulling parts 606 379 7490
CalSnider
Bronze Level Joined: 24 Jan 2016 Location: Wisconsin Points: 1 |
is there anyone in the midwest that can grind a 426 cam shaft?
Peterson
No limit manufacturing in Marshfield wi
Peterson
Hate to be the one always asking, but any update?
ac720nut
Orange Level Joined: 09 Feb 2016 Location: Dexter Mi Points: 1217 |
Peterson, how's your ride coming? Lost track of your thread.
