boost pressure? |
Toscani NE SD
Orange Level Joined: 21 Jan 2011 Location: Milbank S.D. Points: 369 |
Posted: 14 Mar 2015 at 10:41pm |
is there a formula for HP going by boost pressure?on my xt 190 III,it has a 30lb boost gauge and it will peg that about 3/4 down the track and a nice flame out the pipe
Orange Level Access Joined: 12 Sep 2009 Points: 19570 |
I know in one twin-spin 301 A-C Puller, 100 psi intake boost relates to near 1000 flywheel HP on the dyno. By that math, 30 psi would be 300 HP. This is only a theoretical calculation and your results may be different. Seems like a 7020 tractor was around 18-20 psi making 120 PTO HP which would be 145 flywheel HP.
Beirnesy
Orange Level Joined: 30 Jun 2012 Location: Mid Western Ont Points: 351 |
I may be asking a stupid question, Does your xt still have PTO shaft? if yes, dyno it and let us know the hp !!
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
wi50
Here's the quick and dirty of it. Your engine doubles for every atmosphere of boost. So if you have 80 HP naturally aspirated, with 15 psi you have 160, with 30 psi you should see about 240 HP. Now there's thermal inefficiency because you heat the intake air with a turbo and some other factors to subtract. Then come changes in can and cylinder head, fuel system etc.
So the engine pushing 7 atmospheres boost (approx 100psi) making 1000 HP has had to have some other modifications of course, but is limited by its cylinder head. Another engine with a better cylinder head pushing 100 psi may make 1300 a d yet another of that size could make 1800. The 301 heads just aren't great for making big HP, but the cylinders are small, a d they like rpm. |
Peterson
Orange Level Joined: 05 Mar 2011 Location: Westboro, Wi Points: 862 |
More boost does not mean more horse power. Boost is just a restriction on the intake path.
