3pt Question
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Topic: 3pt Question
    Posted: 13 Apr 2016 at 9:22am
I picked up this 3pt. to use on D15 , all seems to fit correctly. Was told it came off a D19 but I don't know about that. What I was wanting to know is,what is the center bracket on cross bar used bar for ? Sway chain ?? If so it looks to be on backward for that use. Thanks
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 9:31am
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 9:33am
the top link connects to it
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 9:35am
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 9:37am
Otherwise the traction booster won't work correctly if the toplink it mounted to the tractor
Charlie
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 9:37am
Thanks - but that would be crossing the PTO shaft ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 9:40am
Yes, it only works for non-pto implements
You need the top link connected that goes under the seat mount for PTO work.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 9:41am
Charlie
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 9:43am
Charlie- I see ! Thank you very much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 9:43am
Charlie
TED View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TED Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 10:56pm
Thanks for all this info and diagrams/pics. I recently bought a WD 45 that does not have the anchor and sway chain. Am a new AC owner. Was disc'ing this past weekend and the bar beneath the tractor came out from under the tractor and dung into the dirt. The 3 pt disc almost ended up on my seat. I have run Fords, Molines,IHs,and etc. but never an AC. This was a real awakening. Looks like I need to add some parts to this tractor that someone discarded a long time ago.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 7:55am
If you are using PTO equipment you'll most likely need to remove the spreader bar from the wishbone. Both my mower and snowblower the PTO shaft hits the crossbar when lifted full up. It hit hard enough to destroy the shield before I stopped it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 8:34am
Originally posted by TED TED wrote:
Was disc'ing this past weekend and the bar beneath the tractor came out from under the tractor and dung into the dirt. The 3 pt disc almost ended up on my seat.  Looks like I need to add some parts to this tractor that someone discarded a long time ago.
What you probably need to do is inspect and repair the latch in the Snap Couple Bell. A broken or weak spring, a wore "latch hook" or the release chain too tight can all add to this happening.
 With the Snap Couple system, the lift latches on the lift arms of the rock shaft are supposed to release with upward movement like that.
http://www.tractorshed.com/gallery/uptest/a69002.jpg
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 8:47am
Ted I had that happen to me 30 + years ago. That is when I found out about that snap coupler spring that needs to be replaced more than 1 time in 50 years. I have a huge scar on my back where the plow landed on me and have has severe back problems ever since.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 9:41am
The good thing is that you appear to have a real A-C adapter.
The chains are not really for anti sway; they are there merely to keep the lower arms under control so they won't swing out and hit the tires. They are not heavy enough to control the sway of a heavy piece of equipment like a bush hog.
When PTO operated equipment is used, the 3 PH is equipped with an anti-sway device (stabilizer)  like the one in the first picture below.
The top link is then attached to a clamp attached to the rocker shaft which can be seen in the second picture.
Edited by Brian G. NY - 14 Apr 2016 at 9:45am
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 11:58am
Brian , that is the system on my D12. May try to fabricate one since one of those will be to hard to locate . Thanks
This page was generated in 0.648 seconds.
