2 way plow question
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 2 way plow question
    Posted: 02 Jun 2010 at 8:06am
I located a 2 way plow for a C, I assume that this is the same one that a B used, but would the mounting gear work on my B?
Charlie
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 9:48am
The plows are the same but the added drawbar for plows will be different width.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 10:34am
The final drive brackets, the drawbar and the depth adjustment assembly is all different.
The rockshaft on a C is also different than the B rockshaft.
The beams, coulters, bottoms and some of the hitch are the same.
They are different enough that the Dealer Parts Manuals are separate for B and C pickup plows.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 11:00am
As they said the B and C pick up plows share no parts except the plows themselves, it's not a matter of finding a part or two to make them work, you will need the entire hitching and lifting setup for a B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 11:26am
OK, thanks for the feedback. you guys rock!
Charlie
BillyL(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillyL(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 11:26am
Charlie,
I would be interested in the setup for my C if it is reasonably priced. That way you will have some money in case you run across a set for a B. Send me a PM if you are interested in getting rid of it. Is the plow in VA or somewhere close?
Thanks, Billy
Edited by BillyL(SC) - 02 Jun 2010 at 11:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 12:24pm
Pm Sent
Charlie
