616/620 alternator conversion
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: 616/620 alternator conversion
    Posted: 08 Apr 2016 at 7:02am
Can somebody point me in the right direction of somebody that has done this?  I'd like to start a swap on my ccka and want to check mounting and pulley info.
Thanks!
David
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 1:58pm
if mine goes bad and i still have a onan in it i am going to mount a pulley on the pto shaft put a gyro and reg off a kubota on it between clutch and trans.   that was my  thought.        some have put a smallersize battery in and mounted a small denzo  alt in the battery  tray  with a pulley on the crank
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 2:09pm
720nut done it to one of his. I believe the he had a write up about how he done it on the SimplicityAC page.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 3:18pm
hudco that's what i'm planning for.  mine hasn't failed that i know of yet and i do have spare parts but I really don't want to pull the engine again.
Thanks tadams
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 3:33pm
tadams you got a link to that home page?
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 10:32pm
google:    simpletractors.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 11:01pm
that is were  i seen the alt was on simpletractors was looking while i was gassing up to sub soil the garden before i take the duels off and i think one of those little gyros would fit up front on the right side with out haveing to use a smaller battery
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2016 at 7:50am
Does direction of rotation matter with an alternator
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2016 at 12:17pm
That's what my idea started out as. Mounting a small Denso up front on a seperate pulley. I did take a couple pics, but being I was still in the designing stages yet when the cold weather set in, I haven't had the time to go out and doing anything yet. Between the high winds we were getting and the cold snap, I've been busy at work keeping out trucks going so the linemen can stand poles back up again and hang new wire. I'll get back to it this Spring if it ever warms up again. I have a few idea's in mind...
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 6:13am
I've got my build documented on Simpletractors. It is a Densco mini alt with 420 amp L&G battery for space. Mine is also a dedicated loader tractor so I replaced front clutch with a pulley so as to have live hydraulics, I'm sure same can be done with clutch. Here is address to thread  simpletractors.com/club2/topic.asp?TOPIC_ID=154806
Edited by ac720nut - 11 Apr 2016 at 6:17am
