WD45 Fluids
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Fluids
    Posted: 27 May 2010 at 10:00pm
Drained the cases on my 45 and Im getting ready to fill them back up....what do they require? Everything looked like standard gear lube but not sure what weight other than the wet clutch looked to have something different....also where do I fill the rear diff? or does it fill from the trans? I wasnt sure because they had separate drain plugs. Any help is great. thanks
John In. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 12:44am
 There are three filler plugs, all are on the left side. rear one is down by the foot rest for diff.   middle one is down by tranny, fill them with 80-90W (takes about 17 qt. add one more if you have a PTO) and the third is the dipstick for the hydraulics, you fill them with hydraulic fluid, not sure of amount for that.    HTH.   John
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 6:35am
Believe that you can use Hy-Trans for all three.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 7:14am
I put hytran fluid in everything in my 45 after replacing 3rd gear back in 1982. It ain't so stiff when I want to plow snow now. No problems in 28 years.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 8:51am
Everyone has different opinions but I use the 80w90 in the trans and 20 wt hydraulic oil in the hydraulic system. Im sure it will all work fine I just prefer the heavier oil because of leaks and better gear lubrication.
David Grubb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Grubb Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 11:04am
There is also a drain plug on the bottom at the rear of the hydraulic pump control unit and one on the bottom of the PTO unit. The plug on the bottom of the hydraulic reservoir has a magnet in it that needs to be wiped clean. There are filler plugs on the inner faces of each final drive unit, no drain plugs, you just top off the pans.
Dave
This page was generated in 0.071 seconds.
