hand clutch
bs5230 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bs5230 Quote  Post ReplyReply Direct Link To This Post Topic: hand clutch
    Posted: 26 May 2010 at 6:38pm
where can i find how to fix a handclutch- i found a large heavy gauge retaining wire in the compartment where the hand cl is-   the tractor stopped moving so i took the inspection plate off under the battery box, and found the big wire,  the foot clutch appears to be working, but i put it in gear and it wont move--the handclutch spins but not the shaft going to the rear end-     but i jacked it up and spun the tire around and the shaft coming from the rear end does turn,, ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 6:48pm
Darins store on this site sells manuals. Help support this site and buy one.
http://www.3000toys.com/allis/manuals.asp
Email me at 1954wd45@gmail.com and I will send you a copy of the hand clutch R and R page.
This page was generated in 0.223 seconds.
