CA Hand Clutch
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Topic: CA Hand Clutch
    Posted: 25 May 2010 at 5:49pm
Got one slipping. Where is a good place to get parts and what does it typically cost to rebuild one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 6:41pm
I've never done one but I know a place like Mutual Wheel will reline the clutch discs with modern materials. Several guys on here have redone them lately.
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 7:46pm
I tore mine out myself and took to Paul B. in MD to rebuild.  He ordered all the parts, put the clutch back together,  all I had to do was put it back in.  I also replaced the seal going into the differential, and both brake bands at the same time.  For all the parts and labor for the clutch from Paul was about $450 and that included the brake bands.  It was the best thing for me because he has a much greater understanding of the hand clutch and also told me all the tricks to tearing it out and putting it back in.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 7:47pm
Also I believe Sandy Lake would be the most knowledgable place to get parts for this.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 8:22pm
Have Facings and rivets when your ready, also spare parts clutch if you want used parts.
Wil M (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil M (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 9:19pm
AGCO still has most of the parts for these.  Cost will depend on what all is wrong with yours and what you can do  your self.  I rebuilt mine going on a year and 1/2 ago and replaced the pads, main bearing, bushing and all of the springs.  If I remember right, it cost me around $250.
If you tear it apart, do not loose those ball bearings, they are expensive! (Luckily I didn't have to replace them but I remember the pricing was expensive.)
The new parts:
Clutch parts:
Clutch put togther before going back into tractor:
"Yet there are soulless men whose hand and brain tear down what time will never give again." Anderson M Scruggs
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 9:34pm
Wil, Thanks for the pics. I did the same when I rebuilt the hydraulic pump. Laid it all out on a piece of cardboard, took pics and documented the repair.
