H3 Grousers
wildcat2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildcat2 Quote  Post ReplyReply Direct Link To This Post Topic: H3 Grousers
    Posted: 22 Feb 2016 at 7:02am
Does anyone know of a source for grousers for a H3 dozer? Has anyone used the weld on grouser bars?
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2016 at 5:34pm
I welded on 5/8" rebar (weldable type not regular rebar) and that worked out really good. It was not on my H3 mind you but my other track loader. The undercarriage shop kind of ridiculed my idea and said it wouldn't last...10 years later they were still really good.
Edited by Eric B - 22 Feb 2016 at 5:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildcat2 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2016 at 7:20am
Didn't think of that, good idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2016 at 5:44pm
On a loader the rebar works great - been on my HD5G for 20 + years .
HD4 loader I had I did the same to as well as a D6 9U I had -
For my FD5 I will buy grouser bar - weld on type to get extra height .
Several styles of bar are out there - do web search .
Single bar on doser is all you need but on loader 2 or 3 are needed so turning does not put extra strain on track .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2016 at 5:53pm
I totally agree, when I put in my first response on this thread I should have also said that on a blade machine you need the tall grouser bars. The ready to weld bars are very good with the bevels in place. Another time you don't want rebar is if you are truly restoring a machine...it just doesn't give you the right appearance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2016 at 6:16pm
On my HD5G I welded 2 bars onto the pads leaving the center space open - has worked ok
On a machine I sold I gave guy the rebar I had cut - next time I seen him he had only 1 bar on each pad on center of pad ..
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2016 at 11:27pm
had a hd-5 that i welded 15/16 grouser bars on. used it to log so once in a while i would get up on a rock and just pound the heck out of them. never broke one off. welded them on with 7018 rod.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2016 at 11:16am
When welding them on the HD5G, I used 7024 drag rod after doing a tack weld with 6011.
 I set bars in place at front and rear of track so I was doing a horizontal weld onto bars - this way a high deposit without worrying about controlling bead height.
 I also used rebar on the HD4G tracks as well as HD5B dozer track but used 7018-AC rod- On my D6 9U when I welded rebar onto those pads I used 70E wire feed as I had moved up in welders.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2016 at 8:10pm
welded grouser bars on a d6h. precut and beveled. the only thing we should have done was bend the ends slightly. with the bars straight, it would tear up everything when turning especially blacktop and concrete when in the shop. if you look at a new pad they are not as high on the outside edges.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2016 at 11:05pm
when I welded the grousers on my 5 a fellow told me to cut the corners off at about a 45 degree angle. worked fine. Leon
Roach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roach Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2016 at 9:17pm
Got mine from for my FL7 about 5 years ago. Came in 10 foot lengths, already beveled and I just cut to length. Angle gut the ends and welded on with 7018 rod. Have never lost a one. Real reasonable on cost.
S Cohn & Son Co Inc in Washington
Tractor Equipment & Parts (Wholesale)
Highway 50 E
Washington Indiana 47501 IN
1937 WC, 1948 G,1954 CA,1956 WD45, 1967 D17, 1937 M crawler, 1963 D-19, 1966 190XT, 1967 D-15, 1948 HG42 Cletrac, 1955 G456 Terra Trac, CAT 10 1928 and CAT 22 1938
