|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| Woods Question |
| Post Reply   |
| KD8NGV   Bronze Level     Joined: 03 Oct 2010 Location: Ohio Points: 178 |  Post Options  Thanks(0)  Quote  Reply  Topic: Woods Question Posted: 16 Feb 2016 at 3:01pm |
   Hello all, My father and I both have woods mowers on our tractors. I have the L306 on my C and he has the 59 on his Farmall A. The problem on his red headed step child is that the mower must have been put after it was ordered for another tractor. It has the wrong spindles installed. We found this out when I routed the belt correctly and it turned the wrong way. Instead of purchasing 3 new spindles at roughly $150 a piece, can we --safely-- route the belt to make the deck spin the correct way? The belt was flipped near the PTO pulley to make this work the time we acquired it. I was not comfortable with it running the wrong way so I routed it correctly and here we are. Will putting on spindles work on a deck that is meant for another handed spindle? Any insight is appreciated. I am working on him to get an Orange girl, but we will see what happens. :) Thank you, Kevin | |
| CTuckerNWIL   Orange Level     Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |  Post Options  Thanks(0)  Quote  Reply  Posted: 16 Feb 2016 at 3:32pm |
The decks are the same for right or left hand spindles. The only difference is the threaded hole in the bottom of the spindle, the bolt and the blade.  I had a Woods 59 on a B and had trouble keeping a belt on it. I didn't change the spindles to run it left handed, I just bought left hand blades and used my 1//2 impact to tighten up the blades. Only had one come loose after that in 4 or 5 years of mowing. There are guys running right hand decks with Allis B's and C's but you gotta figure out how to route the belt to keep it working. Dick L posted a couple times about running his right hand deck and seems to get by well with it. Edited by CTuckerNWIL - 16 Feb 2016 at 3:35pm | |
     http://www.ae-ta.com  Lena 1935 WC12xxx, Willie 1951 CA6xx Dad bought new, 1954WD45 PS, 1960 D17 NF | |
| KD8NGV   Bronze Level     Joined: 03 Oct 2010 Location: Ohio Points: 178 |  Post Options  Thanks(0)  Quote  Reply  Posted: 16 Feb 2016 at 7:37pm |
   Charlie,  I appreciate your feedback.  Is it ok to cross the belt over to make it turn the spindles correctly?   We tried mowing with the correct blades on the incorrect spindles, albeit without the impact, and the blade flew off within the first 5 feet. | |
| norm[ind]   Orange Level   Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |  Post Options  Thanks(0) ![Quote norm[ind] Quote norm[ind]](forum_images/quote.png) Quote  Reply  Posted: 16 Feb 2016 at 8:01pm |
     it iis hard do what you want  ih runs the oppsite the way they are belted up- plus the safety reasons  sold them many yrs   not safe in my book bolts are also lh thread check yours .
| CTuckerNWIL   Orange Level     Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |  Post Options  Thanks(0)  Quote  Reply  Posted: 16 Feb 2016 at 10:47pm |
   Only time I lost a blade was when I nicked a culvert. 120 lbs of air on a cheapo impact turned all the way up and hammer it for a couple seconds. there's no reason you can't reroute the belt as others have done this. I just gave up after one season of mowing cause I needed new blades anyway, and got the leftys.
| KD8NGV   Bronze Level     Joined: 03 Oct 2010 Location: Ohio Points: 178 |  Post Options  Thanks(0)  Quote  Reply  Posted: 17 Feb 2016 at 7:29am |
   Where did you acquire the spindles? When you reroute the belts, do you flip it over near the pto Pulley or reroute it on the spindle pulleys? | |
| farmtoybuilder   Orange Level     Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1457 |  Post Options  Thanks(0)  Quote  Reply  Posted: 17 Feb 2016 at 7:33am |
   New spindles are available from Woods, Or you can just change shafts and buy correct blade bolts.
| Butch(OH)   Orange Level   Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |  Post Options  Thanks(0)  Quote  Reply  Posted: 17 Feb 2016 at 7:36am |
    Around these parts a person can hardly give away a belly mower, even a nice one.   Consignment auction season is upon us, I would do some shopping if it were me. | |
| Ted in NE-OH   Orange Level     Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |  Post Options  Thanks(0)  Quote  Reply  Posted: 17 Feb 2016 at 9:57am |
   I beleive that   the L306 and the 59 have blades that go in opposite directions. Is it possible that the only problem is that the wrong blades are on the mower?
     CA, WD,  C, 3 Bs, 2 Gs, WC, I-400, 914
| CTuckerNWIL   Orange Level     Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |  Post Options  Thanks(0)  Quote  Reply  Posted: 17 Feb 2016 at 10:04am |
   L is for left hand which includes the bolt threads and the blade. Left hand turns counter clockwise when looking down on the mower in working position. L59 is lefty and a 59 is righty.
| Butch(OH)   Orange Level   Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |  Post Options  Thanks(0)  Quote  Reply  Posted: 17 Feb 2016 at 10:05am |
   And the reason for that is so the blades self tighten.
| Hubnut   Orange Level     Joined: 30 Jul 2014 Location: Gainesville, FL Points: 1817 |  Post Options  Thanks(0)  Quote  Reply  Posted: 17 Feb 2016 at 6:02pm |
 This is amazing to me. These mowers work so well. | |
     1940 B "Lucy" 1941 B w/ Woods L59 "Flavia" 1942 B w/ finish mower "Dick" 1941 C w/ 3-point "Maggie" 1947 C SFW w/ L306 "Trixie" 1972 314H | |
| KD8NGV   Bronze Level     Joined: 03 Oct 2010 Location: Ohio Points: 178 |  Post Options  Thanks(0)  Quote  Reply  Posted: 17 Feb 2016 at 7:14pm |
   I have the L 306 on my C and I love it.  As long as I do not get into too high of grass, the old girl works well.  Makes 3.5 acres much easier to manage.  I have to trim the trees or I am liable to lose a head or muffler.  :)
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
