718h
AC puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC puller Quote  Post ReplyReply Direct Link To This Post Topic: 718h
    Posted: 26 Jan 2016 at 4:13pm
Hey guys i have a 718h that when you set your speed and leave it,itslows down going up a grade and speeds up going down.Also if it sits for some time after starting up you have to rev it up to get the rearend to kick in.Anyone got any ideas or words of wisdom? Thx
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2016 at 5:21pm
When was the last time the hydro oil and filter changed? First thing I would do is change the Hydro oil and filter and see if that does the trick. The filter may be partially plugged up.
GlenB(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenB(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2016 at 12:35pm
I agree with Steve. I had a Cub Cadet 149 that acted the same way. After an oil and filter change, it was fine. Hope that is all it needs!
Glen
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC puller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2016 at 4:55am
Restored tractor 2 years ago. New axels filter,oil. I'll try it see what happens.
