adjustable ARCH axle B
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Topic: adjustable ARCH axle B
    Posted: 24 Jan 2016 at 9:24pm
   Need info on adjustable arched axle with riveted wheels, I think I have seen pictures??    The spindles slide in or out.
TerraTiger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerraTiger Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 10:11pm
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 10:19pm
AC made a few thousand maybe?  I have one, pretty rough and apart at this time.
Allis Express participant
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 11:20pm
I was told there are two of them. A narrow and a wide arch. Also was told if you wanted to change the spacing, you needed a different tie rod as they were not adjustable. I think they look neat.
ScottMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottMN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 11:48pm
The adjustable arched front axle was available prior to 1940.
Yes, there were 2 front axle lengths (38"-48" & 50"-60"). As mentioned, you needed to switch the tie rod for the corresponding spacing. The Parts Book shows 5 different tie rods available.
I am sure this helped prompt the change to design a more conventional adjustable front axle which did come out starting in 1940.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2016 at 5:04am
Here are a couple:
Gary
http://www.allischalmers.com/forum/forum_posts.asp?
TID=20461&title=b-adjustable-arch-front-axle
http://www.antiquefarming.com/allis-chalmers-B.html
This page was generated in 0.107 seconds.
